Derivation of Lagrange Family of Interpolation functions
The discussion revolves around the derivation of Lagrange interpolation functions, specifically focusing on the formula for linear interpolation functions and the meaning of the ellipsis in the equation provided. Participants explore the conditions under which these functions are defined and how specific cases, such as the calculation of ψ1(ξ), are derived.
  • Some participants seek clarification on the meaning of the ellipsis in the Lagrange interpolation formula, suggesting it indicates a continuation of terms based on the indices.
  • There is a discussion about the conditions under which ψi(ξj) equals 1 or 0, depending on whether i equals j.
  • One participant questions how the specific form of ψ1(ξ) is derived, expressing confusion over the calculations presented.
  • Another participant points out that the definition of ψi is dependent on the number of points n, and provides a specific example for n = 2.
  • Some participants reference external sources, such as textbooks and Wikipedia, for further clarification on the topic.
Participants express varying levels of understanding regarding the derivation of the interpolation functions, with some agreeing on the meaning of the ellipsis while others remain confused about specific calculations. The discussion does not reach a consensus on the derivation of ψ1(ξ).
There are unresolved questions regarding the assumptions made in the derivation of the interpolation functions, particularly concerning the specific values of ξ1 and ξ2 in the context of n = 2.
bugatti79
Folks,
I am puzzled how the linear interpolation functions (see attached) were determined based on the following equation below
##\displaystyle \psi_i=\frac{(\xi-\xi_1)(\xi-\xi_2)...(\xi-\xi_{i-1})(\xi-\xi_{i+1})...(\xi-\xi_n)}{(\xi_i-\xi_1)(\xi_i-\xi_2)...(\xi_i-\xi_{i-1})(\xi_i-\xi_{i+1})...(\xi_i-\xi_n)}##
What do the dots represent above?
and
[itex]\psi_i(\xi_j)= 1[/itex] if ##i=j## and ##0## if ##i\ne j##
For example how is ##\psi_1(\xi)## determined?
thanks
bugatti79 said:
Folks,
and
thanks
The dots mean fill in all the like terms for indices between the given. In this case, 3 to i-2 and i+2 to n-1.
For the second question, when j = i, the numerator and denominator are the same. When j ≠ i, one term of the numerator product = 0.
Sorry, I still don't follow...
I don't see how ##\psi_1(\xi)=\frac{1}{2}(1-\xi)## is obtained...?
bugatti79 said:
Folks,
The dots (...) are called an ellipsis, and appear as three periods. The ellipsis means "continuing in the same fashion." The first missing factor in both the numerator and denominator would be (x - x3) and the next would be (x - x4), and so on. (I don't see any purpose in writing ##\xi## when plain old x will do just fine.)
like any other dots like that which you see in a mathematical expression. it means "fill in the blank" with the continuing pattern.
it's not as good as my Applied Engineering Mathematics book from Kreyszig, but the wikipedia article on Lagrange polynomials should have the answers to your question.
bugatti79 said:
Folks,
##\displaystyle \psi_1=\frac{(\xi-\xi_1)(\xi-\xi_2)(\xi-\xi_{0})(\xi-\xi_{2})(\xi-\xi_1)}{(\xi_1-\xi_1)(\xi_1-\xi_2)(\xi_1-\xi_{0})(\xi_1-\xi_{2})(\xi_1-\xi_1)}##...?
ξ1 - ξ1 is NOT a term in the denominator. Look at the definition of ψi, the ith term is left out of the numerator and denominator.
Where did you get the expression for ψ1(ξ)?
Its the first equation shown in the picture in first post...
The pictures are slightly criptic. The important thing is that the definition of ψi depends on n. The particular item you ask about is for n = 2.
In that case:
ψ1(ξ) = (ξ-ξ2)/(ξ12), where ξ1= -1 and ξ2=+1.
In that case:
OK, thanks
  • · Replies 36 ·
