Yet Another Simple Tension Problem
  • Thread starter Thread starter wetcarpet
    Tension
The discussion revolves around a tension problem involving a bird feeder supported by three cables, with a focus on calculating the tension in each cable based on given angles and forces. Participants are exploring the relationships between the forces acting on the cables and the geometry involved.
  • Mixed
  • Participants discuss breaking down the problem into components and setting up equations for the net forces in both x and y directions. There is an exploration of why previous methods of dividing tensions do not apply in this scenario.
Some participants have provided guidance on setting up equations to solve for the tensions, while others express confusion about isolating variables and solving the equations. There is ongoing exploration of different approaches without a clear consensus on the final answers.
Participants note the complexity of the angles involved and the need for careful consideration of the forces acting on the system. There is mention of potential algebraic difficulties and the impact of different angles on the tension values.
wetcarpet
A 198N bird feeder is supported by three cables. Find the tension in each cable.
For the angles, see this picture: http://www.webassign.net/sf5/p4_13.gif
{a} Yet again, I split the larger triangle in two by using a positive 198N force, making the large triangle's lower 90 degree angle into a 30 degree angle on the left, and a 60 degree angle on the right.
{b1} Thus, for the tension in the left string:
sin(60) = 198N/Hypotenuse
Hyp. = 198N/sin(60)
Hyp. = 228.6N
--Yet, this value is not the answer, and dividing by two does not work in this instance.
{b2} And for the tension in the right string:
cos(30) = 198N/Hyp.
Hyp. = 198N/sin(30)
Hyp. = 396N
-- Again, this is not the right answer, and divding it by two does not work.
What am I doing wrong?
You need to consider both angled strings at the same time, setting up their net forces in both the x and the y directions. You will them get a system of equations that you can solve for the individual tensions.
The reason dividing by two worked in your other post is because the angles were equal, they shared the weight of the hanging object. In this problem you will find that the strings have different tensions.
Okay, I tried your method to the best of my ability, and the answer I got was 457.3N for the right string. Is that the correct answer? And if not, could you perhaps explain the process better to me so that I can retry it? Thank you for replying.
Ok, let's start with the x direction. The net force in this direction is zero N, so you can set up your first net force equation with this. I will call the string on the right 1, and the one on the left 2
(T1)cos(30)-(T2)cos(60)=0
I used minus because they are in opposite direcion, you could also measure the angle from the same starting position and we wouldn't need to manually put the minus in. Anyways, now we need to figure out an equation for the y axis. We know the net force is 198N, and that all of this force is on the y components of our two strings.
(T1)sin(30)+(T2)sin(60)=198
Solving these for T1 and T2 should give you the correct answers for the top two, the tension in the third string should be obvious.
Okay, I follow your logic thus far, and it makes perfect sense. My only problem is that I am not sure how to solve those equations without at least one value plugged in for T1 or T2. Again, I'm sure it's something right beneath my nose that I'm neglecting here. :smile:
Substitution, solve one of the equations for one of your unknowns, say T1
T1cos(30)-T2cos(60)=0
T1cos(30)=T2cos(60)
T1=(T2cos(60))/cos(30)
Substituting this into the other equation will allow you to find T2, then to solve for T1 simply plug the value you found for T2 into the above equation.
Again, I follow your logic perfectly, but another difficulty has cropped up. How on Earth do I isolate T2 in this monster?
((T2)cos60/cos30)sin30+(T2)sin60 = 198
I have made several attempts at this already, and all were failures- forcing me to realize that I need to brush up on some Algebra, hehe.
It is easiest if you simply throw all those evil trig values into your calculator, or you could recall that
sin(30)=0.5
cos(60)=0.5
cos(30)=Sqrt(3)/2
sin(60)=Sqrt(3)/2
The equation simplifies to
[tex]\frac {0.5}{\sqrt{3}}T_{2}+\frac{\sqrt{3}}{2}T_{2}=198[/tex]
[tex]\frac{4\sqrt{3}}{6}T_{2}=198[/tex]
[tex]T_{2}=\frac{297}{\sqrt{3}}[/tex]
or [tex]T_2\approx171.473[/tex]
I sincerely thank you for your time and patience. :smile:
No problem, it was either
a) help you, rip my cds onto my computer, and read my book
or
b) write my english paper that is due tomorrow
and I really didn't want to write that paper. Well, now it is 3:30 in the morning and I have gotten about half of it done. This is really not a good way to start my week...
