Finding the z component of vectors that form a triangle?
The discussion revolves around finding the z components of cross products of vectors that form a triangle, specifically vectors a, b, and c with given magnitudes. The original poster expresses confusion regarding the application of vector notation and the cross product formula.
  • Participants discuss the use of the cross product formula and the significance of angles between vectors. The original poster questions their understanding of the z component calculations, particularly when applying the formula to different vector pairs.
Some participants have provided guidance on using the cross product formula and highlighted the importance of directionality in the results. There is an acknowledgment of the need to consider the signs of the components based on vector relationships.
The original poster is working with limited information, focusing on the magnitudes of the vectors without full vector notation. There is a mention of a diagram that may aid in understanding the relationships between the vectors.
rockchalk1312
For the vectors in the figure, with a = 1.1 and b = 2.6, what are (a) the z component of a x b, (b) the z component of a x c, and (c) the z component of b x c?
Everything I've tried to look up involves vectors that are in unit notation, etc. I just don't understand how to do it when all you have for the vector is one number.
With the information given, you can work out the angle between a and c.
Then use the formula for the cross product which uses the magnitudes and angle.
So using a x b = |a| |b| sinθ told me that the z component of a x b = (1.1)(2.6)sin90 = 2.9.
And for b x c = (2.6)(2.823)sin(90-67.07)=2.9.
These were both correct, but then when I tried to do a x c = (1.1)(2.823)sin67.06 = 2.9 this was the wrong answer.
Am I missing something completely obvious?
Thank you for your help!
That should be |a x b| = |a| |b| sinθ. If you want a x b, not just its magnitude, you need to worry about direction. Yes, it's in the z direction, but is it positive or negative? You need to apply the convention for a x b (as distinct from b x a) to determine that.
From the diagram, you have a + b + c = 0. So 0 = a x (a + b + c) = a x a + a x b + a x c = a x b + a x c. It follows that a x b and a x c must have opposite signs.
Perfect THANK you that was certainly what I was missing.
  • · Replies 21 ·
