Finding the sum of a trigonometric series
The discussion revolves around finding the sum of a trigonometric series involving terms of the form \(1 + a \cos \theta + a^{2} \cos 2\theta + a^{3} \cos 3\theta + ... + a^{n} \cos n\theta\). Participants are exploring methods to derive the sum, referencing complex numbers and binomial expansion.
  • Participants discuss using de Moivre's theorem and the geometric series sum to approach the problem. There are attempts to express the series in terms of complex exponentials and to identify the real part of the resulting expression. Some participants express confusion regarding the application of these concepts and the definitions of certain terms.
The discussion is ongoing, with various methods being suggested, including the use of complex numbers and geometric series. Some participants are questioning their understanding of the concepts involved, while others are attempting to clarify the relationships between the terms in the series.
Participants note that they have not learned certain advanced topics, such as the multiple angle formula, which may be relevant to the problem. There is also mention of constraints related to their current level of study in high school mathematics.
Skyrior
1. The problem statement
Find the sum of the series:
a. [itex]1 + a cos θ + a^{2} cos 2θ + a^{3} cos 3θ + ... + a^{n} cos nθ[/itex]
Apparently, the answer is:
[itex]\frac{a^{n+1}(a cos nθ - cos(n+1)θ) - a cos θ + 1)}{a^{2} - 2a cos θ + 1}[/itex]
2. The attempt at a solution
= The real part of [itex]z^{0} + z^{1} + ... + z^{n}[/itex]
= [itex]1 + a cos θ + a^{2} (cos^{2} θ - sin^{2} θ) + a^{3}(cos^{3} θ - 3 cos θ sin^{2} θ) + ... + a^{n}(cos nθ)[/itex]
(Basically, binomial expansion)
I continued on, but I got something I couldn't understand:
= [itex]1 (1 - a^{2} + a^{4} - a^{6} + ...) + cos θ (a - 3a^{3} + 5a^{5} + ...) + cos^{2} θ (a^{2} - 8a^{4} + 18a^{6} + ...) + cos^{3} θ (4a^{3} - 20a^{5} + 56a^{7} + ...) + ... + cos^{n} θ (2^{n-1} a^{n} - ?)[/itex]
I think the right way to the solution is much simpler than this, but I just couldn't figure it out...I'm stuck on it for hours...
3. Relevant Equations
n.a.
We are supposed to know binomial expansion, binomial expansion of complex numbers, De Movire's Theorem, roots of complex numbers, double angle identity, trigonometric addition formula.
We didn't learn: multiple angle formula, Hyperbolic Functions.
There was a previous question that asks you to:
"Use complex number methods to show that ..."
So I presume that the question I asked is also about complex numbers...
btw, I'm currently in high school, specifically taking IB Math HL, I'm not familiar with the multiple angle formula: http://mathworld.wolfram.com/Multiple-AngleFormulas.html (I don't think we learned that). We learned De Movire's Theorem though. I think I might be using the theorem in a wrong way. Thanks for any help!
[itex]= 1 (1 - a^{2} + a^{4} - a^{6} + ...) + cos θ (a - 3a^{3} + 5a^{5} + ...) + cos^{2} θ (a^{2} - 8a^{4} + 18a^{6} + ...) + cos^{3} θ (4a^{3} - 20a^{5} + 56a^{7} + ...) + \dots\\ \dots\ + cos^{n} θ (2^{n-1} a^{n} - ?)[/itex]
De Moivre's theorem should do it. (Euler's theorem works as well or better.)
Do you know the sum for a finite geometric series? It's not difficult to derive.
Let [itex]\displaystyle \ S=\sum_{k=0}^{n}r^k=1+r+r^2+\dots+r^{n-1}+r^n \ .\[/itex]
Then [itex]\displaystyle \ r\cdot S=r\sum_{k=0}^{n}r^k=r+r^2+\dots+r^{n-1}+r^n+r^{n+1} \ .\[/itex]
Look at rS - S and solve for S .
We didn't learn Euler's Theorem but we learned sum for a finite geometric series.
Sorry, but I still don't think I get it. I'm sorry for not stating it, but I did attempt to use geometric series, but I don't know what is r. I think r should be something like [itex]a (cos 2θ/cosθ)[/itex] but [itex](cos 3θ/cos 2θ)[/itex] seems to be different from cos 2θ/cos θ.
ehild said:
Complex numbers can be written in exponential form: http://mathworld.wolfram.com/ComplexNumber.html
z=r(cosθ+isinθ)=r e.
The series is the real part of z0+z1+z2+z3...
What do you get if you replace z by a*e?
ehild
erm...I'm quite dumb...I still don't get it.
Sum of series of real+imaginary would then be: [itex](1-(a(e^{iθ}))^{n})/(1-(a(e^{iθ})))[/itex]?
Uh...
Well, I'm really confused. I know how to get to this part, but I never know how I could remove the imaginary part.
The real part of the series is
= [itex][1-a^{n}cos(nθ)]/[1-a cos(θ)][/itex]? It just doesn't make sense to me...
erm...Is it OK to do so? Because I don't think it is right anyways
I thought again, and I think [itex]a^{2} - 2a cos θ + 1[/itex], the denominator of the answer, is the expansion of [itex](x-y)^{2}[/itex]. But I don't know how to get it nor what should be x and y.
Thank you for both of your help, but I don't think I would want to continue on this question, it has already wasted half of my day and within my brain capacity I will never be able to comprehend it anyways...
Multoply both the numerator and denominator by the conjugate of the denominator.
ehild
Let's go back & see if we can solve this using de Moivre's formula pretty much straight up.
Let U be the series defined as follows.
[itex]\displaystyle U=<br /> \sum_{k=0}^{n} \left(a\left(\cos(\theta)+i\sin(\theta)\right)\right)^k[/itex]
[itex]\displaystyle \quad\ \ =1+a\left(\cos(\theta)+i\sin(\theta)\right)+<br /> a^2\left(\cos(\theta)+i\sin(\theta)\right)^2+\ \dots\ <br /> +a^{n}\left(\cos(\theta)+i\sin(\theta)\right)^{n}[/itex]​
Applying de Moivre's formula to the above result, can you see that the real part of U is the same as the series you're to evaluate?
Please note the different between cos(2x) and (cosx)^2 (sorry I'm lazy to find the delta symbol).
so we use alternative form of expression for cosx = 0.5[e^(-ix)+e^(ix)] and your equation can simply solve with finite geometric series?
  • · Replies 21 ·
