How air pressure reacts in a car tyre.
The discussion centers on the relationship between air pressure and tire size in car tires, specifically comparing a 205/55/16 tire to a 205/40/18 tire. Participants agree that while the pressure may not need to change significantly with tire size, the volume of air and tire profile do influence the tire's shape and performance. It is established that even minor changes in tire volume can lead to substantial variations in the contact patch area, which affects load distribution. Thus, while a consistent pressure may be maintained, adjustments may be necessary for optimal performance based on tire design.
  • Understanding of tire specifications (e.g., 205/55/16, 205/40/18)
  • Basic knowledge of air pressure principles
  • Familiarity with load distribution concepts in automotive engineering
  • Awareness of how tire profile affects vehicle handling
  • Research the impact of tire profile on vehicle dynamics
  • Study the relationship between tire pressure and contact patch area
  • Learn about tire wall thickness and its effect on performance
  • Explore temperature effects on tire pressure and performance
Automotive engineers, tire manufacturers, car enthusiasts, and anyone involved in optimizing vehicle performance through tire selection and maintenance.
burnzybubbles
hello to everyone, I'm sorry to bother you with what may seen a very easy question but I'm hoping someone can help me with the correct scientific answer.
now there has been a debate regarding tyre pressures in car tyres corresponding with there size and shape, a lot of people say that the pressure should stay the same regardless of shape or size (within reason) as the same pressure of air inside the tyre is holding up the same weight, but i beg to differ as the amount of room to be compressed as in the tyres profile will be reduced or increased, now i know that if you really got deep into it you'd have to take into account tyre wall thickness, temperature plus other things, but for example say you have a tyre of 205/55/16 and a tyre of 205/40/18 same width, nearly the same radius but less volume of air inside the 205/40/18, i think the pressure should be raised to allow the tyre to be the correct shape.
i'm sorry to have littered your forum with such a question but i thought if anyone would know the answer then you guys would, any help on the matter is appreciated, thankyou.
You are right in principle but wrong "within reason", because the change in volume as the load varies is very small, and therefore the pressure barely changes. Even a very small change in tire volume will produce a large increase in the contact patch area - and load carried by the tire is given by the product of the area and the pressure.
  • · Replies 27 ·
9K
