Calculus of Variations: Solving Differential Equations
The discussion revolves around the calculus of variations, exploring its status as a generalization of calculus, the relationship between problems in calculus of variations and solvable differential equations, and the methods for finding solutions to optimization problems such as the shortest path in the xy plane. Participants express varying levels of understanding and propose different approaches to the topic.
  • One participant questions whether every problem in calculus of variations can be framed as a solvable differential equation, expressing concern about the tendency to "guess" solutions.
  • Another participant suggests that deeper knowledge of functional analysis and related mathematical concepts may be necessary for understanding calculus of variations.
  • A different viewpoint emphasizes the importance of setting up expressions to minimize, such as the length of paths, and introduces the concept of test functions leading to the Euler-Lagrange equations.
  • One participant outlines a general approach to optimization problems, drawing parallels with single and multivariable calculus, and discusses the transition to functional analysis where functions are treated as vectors.
  • Another participant provides a detailed example of expressing the shortest path problem using path integrals and functional mappings, emphasizing the need to derive a differential equation from the functional optimization process.
Participants express differing opinions on the necessity of functional analysis for understanding calculus of variations, the nature of "guessing" in finding solutions, and the methods for deriving differential equations from optimization problems. No consensus is reached on these points.
Participants highlight the complexity of the calculus of variations and the potential need for advanced mathematical concepts, but specific assumptions and limitations in their arguments remain unresolved.
This discussion may be useful for students and practitioners interested in the calculus of variations, optimization problems, and the mathematical foundations of these concepts, particularly those exploring the connections between calculus and functional analysis.
V0ODO0CH1LD
My first question is with regards to the "status" of calculus of variations. Because I read in wolfram alpha that it was a generalization of calculus? Is that right?
Anyway; my main question has to do with the process of getting the answer you're looking for. Is every problem in calculus of variations possible to be set as a solvable differential equation? And by solvable I don't mean keep guessing the answer until you eventually get it and then prove it was the right one using some method. Which to me looks like a general trend in calculus of variations.
If you can set at least most problems of calculus of variations as differential equations, how do you go about doing it? Should I look deeper into functional analysis, banach spaces, metric spaces and so on?
Could anyone show me an "algorithmic" way to find, for instance, the solution to the problem of finding the shortest path between two point in the xy plane? Without assuming you already know the answer and is just trying to prove it's the right one?
If you have around 15 bucks or so I recommend: "Mathematics of Classical and Quantum Physics" from Byron and Fuller, Dover Publishing. Forget about deeper functional analysis for a first understanding (<- my opinion).
What do you mean with "guessing"?
I cite the book: "One of the oldest problems in mathematical physics is that of trying to minimize expressions which do not depend on some simple continuous variable, but rather on a function".
That's it. Why should this be something different than "analysis"? Where does "analysis" end? Is "vector analysis" a new one? Or "theory of functions"?
You simply set up an expression (or a couple of them) like
ds = sqrt(1 + y'(x)^2) dx
which you would like to minimize. Here you simply describe the length of the little path pieces. And now you think: Fine, I would like to minimize the path. So you are writing down on a piece of paper the integral. Now you realize: Nice, I have an integral I can't integrate because I don't know the function y(x). Now you think hmmm if I want to have the minimum then the function y(x,epsilon) can only be the minimum if epsilon is zero, meaning you are adding simply something which has to be gone in the end.
Example: Integral from 0 to 1. y(x) unknown. So y(x) + epsilon * sin(x / PI) is an idea. But the test function is not important.
So the brilliant idea is to think about a test function which disappears in the minimum and that function has nothing to do but fulfilling some conditions.
Doing that you will get the Euler-Lagrange equation(s). This means that you have a (set of) differential equation(s) to be solved.
You have a deep lack in understanding if you think that the test functions are the problem. I would say: Have fun with solving the system of differential equations you will get! ;)
For the optimization problem you essentially follow the same steps as in single and multivariable calculus.
In single variable calculus you express the quantity to be optimized as a function of the variable and solve for where the derivative is zero. After taking the derivative this is a single variable algebra problem.
In multi-variable calculus you express the quantity to be optimized as a function of the many variables (which you can call a single vector variable). The derivative generalizes to the "gradient" here i.e. the vector of partial derivatives. You then solve the vector equation you get setting this general derivative to (the) zero (vector). The vector equation is then a system of equations.
In functional analysis a function can be thought of as a vector (infinite dimensional) and you do the same as above except now the "function" of your vector is a functional, i.e. a mapping from the function to a number. This functional has a derivative in the generalized setting and setting it to (the) zero (functional) gives you a continuum system of equations typically expressed as a differential equation on the function at which optimization occurs.
As an example of shortest path. You would express an arbitrary path by giving position as a function of some parameter, i.e. x(t), y(t), and z(t) for 0<t<1. You then need to express how to get the thing to be optimized form the functions, e.g. for distance you have to do a path integral to get arclength...
[tex]s[x,y,z] = \int_{0}^1 \sqrt{\dot{x}^2 + \dot{y}^2 + \dot{z}^2}dt[/tex]
Note here that the arclength s is not a function of the values of x,y, and z but rather a functional of x,y,z as functions of t. (We'd be better off using different names for the variables x,y,z and their functional dependence on t... something like:
[tex]x=f(t), y=g(t), z=h(t)[/tex]
and similarly arclength s as some functional, say Lambda of these functions (I use Lambda to stand for the "L"ength functional.)
[tex]s=\Lambda[f,g,h] = \int_{0}^1 \sqrt{\dot{f}(t)^2 + \dot{g}(t)^2 + \dot{h}(t)^2}dt[/tex]
Now we have this mapping from functions to a number s. We take its generalized derivative which is a linear functional depending on the function (including its derivatives). So setting it to the zero function gives you typically a differential equation.
In summary you in all cases express the quantity to be optimized as a mapping from the variable entity to a number, you in some sense take the derivative of this mapping and set that to the zero object for its type and solve.
  • · Replies 33 ·
  • · Replies 22 ·
  • · Replies 17 ·
13K
