Register to reply
How to develop a RAM Pump with a 300m delivery head?
by P. Akpata
Tags: 300m, delivery, develop, head, pump
Share this thread:
P. Akpata
#1
Apr7-13, 08:30 AM
P: 1
Hey there,
I was just wondering if its actually possible to configure a RAM Pump to deliver up to a height of 300m (984 ft)
I've made a ram that has a delivery head of 35m (115ft) for personal use; however a family friend wants me to set up a RAM for them that goes up to 250m and delivers usable pressure (hence I rounded up to 300m).
I have checked online and found that Green and Carter do RAMs with 300m + delivery head, but the asking price is 5000 GBP and up. Which needless to say is way out of my friends price range.
So can it be done using galvanized parts as a "home-made' project so to speak?
To give some further background information.
- I have scouted the pump area and I expect to be able to get between a 6m and 10m drop for the drive pipe.
- The drive pipe, swing check valve, and spring check valve will be either 2" or 3" galvanized steel.
- The source water will be a raised canal running from a sizable river (previously the canal fed a mill in a citrus, lime, crushing plant). I need to clean out the canal first before I can accurately measure the flow rate, but right now I estimate that I can get at least a 60gpm flow rate.
Thank you very much for your responses.
Phys.Org News Partner Engineering news on Phys.org
Researchers find security flaws in backscatter X-ray scanners
Virtual reality guides those whose memory is failing
Intelligent navigation system to personalise shopping trips
Travis_King
#2
Apr9-13, 01:51 PM
P: 839
300 meters gives you a discharge pressure of around 430 psi, local internal pressures are probably a bit higher. That means you need strong materials, good seals, etc. hence the price. For what it's worth, 5000 bucks for 300 meters of lift is pretty darn good.
Also, that extra 50 meters of lift provides around 70 psi, are you sure you need that much usable pressure?
SteamKing
#3
Apr9-13, 04:07 PM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 6,472
5000 GBP is roughly US $7500.00
Travis_King
#4
Apr9-13, 04:15 PM
P: 839
Still a decent price for a pump with 300 m of head...
CraigAllan
#5
Apr24-13, 02:16 PM
P: 3
Staging ram pumps works well. You can use far cheaper materials if you break the lift into stages. But you need more pumps and a few staging tanks which pushes costs up. I got 80m of usable head from a basic single stage pump.
The target of 300m is very ambitious.
Register to reply
Related Discussions
Slurry pipeline and pump head General Engineering 3
Pump head General Engineering 8
Pump head and flow rate relation Mechanical Engineering 3
Pump Selection/Head Calculations Engineering Systems & Design 0
Head Developed by Centrifugal Pump General Engineering 0
