Magnetic Forces on Moving Charges True or False
The discussion revolves around the behavior of a charged particle moving through a magnetic field, specifically addressing statements about the relationships between magnetic force, acceleration, and velocity. The subject area is electromagnetism, focusing on magnetic forces acting on moving charges.
  • Participants explore the correctness of statements regarding the perpendicular relationships between magnetic force, acceleration, and velocity. There is an attempt to reassess the understanding of acceleration in relation to the magnetic force and velocity.
The discussion is active, with participants questioning initial answers and providing insights into the relationships between the forces and motion of the charged particle. Some guidance has been offered regarding the application of the right-hand rule and Newton's second law, but no consensus has been reached on the correctness of the answers.
Participants express uncertainty about the direction of acceleration in relation to velocity and magnetic force, indicating a need for further clarification on these concepts. There is also mention of the potential for circular motion in a constant magnetic field.
devilaudy
Consider a charged particle moving with velocity v through a magnetic field B. Answer True or False.
1) The magnetic field B is always perpendicular to the acceleration a of the particle.
2) The magnetic force F is always perpendicular to the acceleration a of the particle.
3) The acceleration a of the particle is always perpendicular to the velocity v.
4) The force F exerted by the magnetic field is always perpendicular to the velocity v.
F = qv x B (cross product, magnetic force on a moving charged particle).
I tried 1) false 2) true 3) false 4) true and FFFT, but it was wrong. I was sure about my first answer since the magnetic force is always perpendicular to B and V.
hi devilaudy! :smile:
think about (3) again …
what does the magnetic force equation mean? :wink:
Thank you for answering! I was not really thinking about the acceleration, I thought it would have the same direction as the velocity of the particle! But would it be perpendicular to its motion? Then the acceleration would be parallel to the force exerted by the magnetic field, so the answers would be TFTT. I am not sure if I am getting it right...
^ That looks right to me.
It's easier to think about this with a concrete example. Suppose the particle is positively charged, moving to the right, and the magnetic field points into the page/screen. Use the right hand rule to figure out the direction of the force. What kind of motion does the particle undergo?
(just got up :zzz:)
that's right … good ol' Newton's second law … acceleration is always parallel to force! :wink:
(so in a constant magnetic field, everything goes in a circle …*the faster it goes, the larger the circle … see if you can prove that)
i think you're confusing field with force :redface:
  • · Replies 31 ·
  • · Replies 18 ·
