Precalculus question using trigonometric equations
The discussion revolves around solving trigonometric equations, specifically focusing on the equations involving sine and tangent functions. Participants are exploring the implications of angles in both radians and degrees, as well as the properties of the unit circle.
  • Exploratory, Conceptual clarification, Problem interpretation, Assumption checking
  • Participants discuss how to manipulate the equation 2 sin(x/2) - 1 = 0 and the implications of the sine function equating to 1/2. There is also exploration of converting between radians and degrees, and understanding the unit circle in relation to sine and tangent values.
The discussion is active with participants sharing their attempts and reasoning. Some have provided insights into finding multiple solutions for sine and tangent equations, while others express confusion about the definitions and properties of trigonometric functions. There is no explicit consensus, but several productive lines of inquiry are being explored.
Participants are working off-book and are facing challenges in understanding the definitions of trigonometric functions in relation to the unit circle. There are references to specific angles and their corresponding sine values, as well as the need for clarity on how to derive solutions from the unit circle.
grafs50
Can you all help?
The problem is 2 sin(x/2) - 1 = 0 I don't know what to do with the (x/2).
So far I've done this:
2 sin(x/2)-1=0
2 sin(x/2)=1
sin(x/2)=1/2
Well if the sine of some angle is 1/2, what can you say about that angle?
Now,
sin(x/2) = (1/2)
(x/2) = sin-1 (1/2)
(x/2) = (π/6) (Taking only principal value of sin)
x = (π/3)
Well this is the right idea, but it doesn't for just the principal value. Looking for values just in [0,2π), we get that x/2= π/6 or that x/2=5π/6 so x=π/3 or 5π/3. To get any other value of x, just add one of these values by a multiple of 2π.
Alright. But I need the answer in degrees.
So, I would just convert radians to degrees up there?
And I only understand how to come up with one of those two answers still (plug sin^-1(1/2) into a calculator; which gives degrees).
You should know how to convert radians to degrees. If you want to see how to get all values that give you a sine of 1/2, maybe try to draw a unit circle and see where y=1/2.
I was just making sure that that was in fact radians that I could convert to degrees. So I got x = 210, 330 degrees which is the same as the radian answers I saw above and work in the formula. Thanks for the help!
But I have another problem now... there is an equation (-1)+tan(3x/2)=0
I did this:
(-1)+tan(3x/2)=0
tan(3x/2)=1
then does tan x = 3/2?
x = tan^-1(3/2)? Because that doesn't seem to work.
Never mind, I just got it. x= 30, 210 degrees.
Actually how do I know how many solutions are in sin 2x= sqrt(2)/2?
I found x=22.5, but I don't have 22.5 degrees on the unit circle
Sine equals √2/2 when θ= 45°, 135°, etc. That should help
Thanks, I got 22.5 and 67.5 which seems to be right.
I just really don't understand how sin sqrt(2)/2 equals both 67.5 and 22.5 degrees. They are not the same on the unit circle. What about 112.5 and 157.5 degrees. And different rules seem to apply for tan and cos.
For Sine, does just the y-coordinates have to match? What about for Cos and Tan? We are working off-book so I can't look in the book to find how it works and I'm pretty confused.
sine of a number does not equal any number of degrees! You seem to be very confused as to the basic definition, in terms of the unit circle, of the trig functions. You need to review that.
I agree with HallsofIvy. You need to review the unit circle.
Sin(2(22.5 degrees))= (2^.5)/2
Alright thanks everybody.
  • · Replies 26 ·
