Impedance Matrix of a Potential Divider.
This discussion revolves around the impedance matrix of a potential divider circuit, focusing on deriving simultaneous equations, the impedance matrix relating voltage to current, and the matrix equation relating current to voltage. Participants explore theoretical aspects and practical implications of circuit analysis using matrix methods.
  • Homework-related
  • One participant presents simultaneous equations for the circuit, expressing voltage as a function of current.
  • Another participant simplifies the concept of the impedance matrix, suggesting it is a sophisticated way to describe a potential divider.
  • A different participant notes that current I2 will not flow unless the terminals are connected, raising questions about circuit behavior under different conditions.
  • One participant realizes a misreading of the question regarding the relationship between current and voltage, leading to the inversion of the impedance matrix to derive the admittance matrix.
  • Another participant comments on the unconventional nature of using a matrix for circuit analysis, while acknowledging its potential applications in simulations.
  • A participant points out a possible error in the schematic regarding the direction of current I2, suggesting it contradicts conventional notation.
  • Another participant defends the correctness of their impedance matrix, indicating it aligns with their tutor's perspective, despite concerns about the schematic's representation.
  • One participant emphasizes the importance of adhering to conventions in matrix representation for future reference.
Participants express varying interpretations of the circuit and the implications of the impedance matrix. There is no consensus on the correctness of the schematic or the direction of currents, and multiple views on the appropriateness of using a matrix approach for this problem remain evident.
Participants acknowledge potential limitations in their understanding of circuit analysis, particularly regarding the assumptions made about current flow and the interpretation of the impedance matrix. The discussion reflects a mix of correct and possibly incorrect interpretations of circuit behavior.
CraigH
This question should be quite easy, I'm really struggling though.
http://img32.imageshack.us/img32/5241/potdiv.png
1) Write down two simultaneous equations for this circuit that describe the voltage as a function of current
2)Write down the impedance matrix that relates voltage to current
3)Determine the matrix equation that relates current to voltage
V=IR
Vi = I1Ra + (I1-I2)Rb
Vo = (I1-I2)Rb
2)
[itex]\left[ \begin{array}{c} Vi \\Vo \end{array} \right] = \left[ \begin{array}{cc} (Ra+Rb) & -Rb \\ Rb & -Rb \end{array} \right]\left[ \begin{array}{c} I1\\I2\end{array} \right][/itex]
3)
I don't understand what is being asked here, and it's worth a lot of marks. But so is the last section, so it can't just be the same thing again. What do you think it is asking?
An impedence matrix seems like a very sophisticated way of talking about a potential divider...
Put "simply" the voltage experienced at the load is:
[itex] <br /> \frac{V_{\text{in}}R_B}{R_A+R_B}<br /> <br /> =<br /> <br /> V_{\text{out}}<br /> [/itex]
Another good point to make is that unless the terminals on the right are connected no current I2 will flow.. as there is no path to ground. And if they are shorted then the load is in parallel with no load... and so all of the current will flow through RA only. And if the load on the right is non-zero -> then the question is rather different isn't it. Its rather late here and it's been a long day so I may have fundamentally misunderstood the question or misapplied circuit analysis. Will have another look tomorrow.
Its okay I've got it now. I misread the question, part 3 is "relates current to voltage" and part 2 is "relates voltage to current".
So for part 3 I had to invert the impedance matrix to get the admittance matrix A . And then
I= A * V
A matrix does seem like an overly complicated way to find the currents in a potential divider, I guess it could be used to create simulations or something though. I think this was just an arbitrary example to test our matrix knowledge.
And yes I've also been thinking that no current will flow through I2 if the terminals are not connected. This confused me a bit but I think my answer is still correct.
I think that Vo will be connected by a load, e.g a 10 ohm resistor, but my matrix equation will still be true for any load as the question seems to imply that you already know all the voltages and currents and you just want to work out the resistances.
Like I said though, It's just an arbitrary matrix question.
Im glad that you've solved it. This is a strangely mathematical way of talking about circuit analysis. It is very probably true and yet slightly weird at the same time!
In your schematic you have the I2 current going the wrong way according to the convention usually used. See this page:
http://fourier.eng.hmc.edu/e84/lectures/ch2/node4.html
Notice how the currents are all going into the network (two-port), not out. The way you have done it the 2,2 element of your matrix is negative. That element should be the resistance looking into the network (from the output) with the input open circuited, and it shouldn't be a negative resistance.
Did you draw that schematic yourself, or did you paste from the actual homework assignment? I would check with the instructor about this.
Thanks for the link, its good stuff :)
The diagram was taken straight from a past exam paper.
I think however the impedance matrix is still correct, or at least it is correct in the eyes of my tutor. Like I mentioned earlier this was from my maths exam (as part of an electronic engineering degree), so the question is just an arbitrary matrix question.
I think that arrow showing [itex]V_{0}[/itex] is the wrong way around, as I think that [itex]V_{0}[/itex] is not a voltage source, but a voltage drop across a load between the two nodes of this port. In this case I2 is going in the correct direction, and I will just end up with a negative value for [itex]V_{0}[/itex] if I am to calculate it.
Your tutor makes the rules for homework problems, so you need to do what gets you the good grade.
But, once you're out of that class, be aware that the elements on the main diagonal of a Z matrix should all be (by convention) positive when the elements of the circuit are just plain old resistors.
Thank you I will keep that in mind.
  • · Replies 25 ·
  • · Replies 19 ·
