How Does a Game Boy Circuit Board Function?
  • Thread starter Thread starter QuantumTheory
    Computer Work
The discussion centers around the functioning of circuit boards, specifically in the context of the Game Boy and similar electronic devices. Participants explore how circuit boards operate, how programming code is integrated, and the flow of electricity within these systems.
  • One participant identifies the green component as a circuit board and explains that it contains connections similar to wires, with electricity flowing through them when powered.
  • Another participant mentions that the Game Boy is microprocessor-based, with programming instructions stored on integrated chips on the motherboard.
  • A participant elaborates on the role of ROM in the Game Boy, explaining that it holds software necessary for booting and accessing games, and describes the process of "burning" data onto ROM chips.
  • There is a comparison made between the process of burning data onto ROM chips and burning a CD, noting that both involve creating a permanent pattern that can be interpreted as data.
  • Some participants express confusion over technical terms and concepts, indicating a need for further clarification.
  • One participant expresses interest in building lasers, indicating a desire to learn more about optics, which suggests a broader interest in electronics and physics.
Participants generally share similar views on the basic functioning of circuit boards and the role of microprocessors and ROM, but there is no consensus on the understanding of specific technical terms and processes, leading to some confusion.
Some participants express uncertainty about the terminology used in the discussion, indicating that further clarification may be needed regarding the concepts of ROM, RAM, and the process of programming circuit boards.
This discussion may be useful for individuals interested in electronics, circuit design, and programming, particularly those looking to understand the fundamentals of how devices like the Game Boy operate.
QuantumTheory
If you are familiar with game boy, the gaming company by Nintendo, then i have a question for you. This also applies to any electronic device with a circuit board. It might not actually be a circuit board -- I don't know what it is called. But it is green and has a lot of connections on it. How do they work? How do you get the programming code (instructions) on these? How does the eletricity flow through them? I don't understand circuit boards, and would like some help on this area. Thank you.
That green thing is a circuit board. The connections running all over the place are like wires. Electricity is flowing through them. The batteries you put in the gameboy supply the power. When you flip the "on" switch, you are closing the circuit and allowing electricity to flow.
This part is a guess since I'm not very familiar with the inside of a gameboy:
As to how to program them... well, obviously the unit is microprocessor based. You program the instructions on the chips integrated onto the motherboard (the green thing).
The games are written separately, as I'm sure you know. They are written in a high level programming language.
As for understanding circuit boards, essentially they are the same things as the circuits you built in physics class, with breadboards and wires, etc. All of the chips and wires, and other circuit compenents are packaged on those slim circuit boards.
In addition to the above, there is a microprocessor(similar to the intel or PPC you are using to access this forum, only much much smaller) and some associated ram and rom. The rom holds all of the software needed to boot your gameboy up when there is no cartridge installed as well as the programs needed to access the games stored on the cartridge and any programs needed to decipher the games.
This rom chip(depending on the system it can be external to the microprocessor or internal to the microprocessor) are factory "burned" with all of the required programs. Essentially, the rom chip is connected to another computer(like an intel running windows) and the software is sent from the source(intel) computer to a rom burner(a device the rom chip plugs into to connect to the source). The rom burner applies a higher voltage than the chip normally sees which causes transistors within the rom to burnout. Rom and Ram are simply huge arrays of transistors. The pattern of damaged transistors can be read by the microprocessor and intrepreted as a program.
The process is very similar to burning a CD except a CD is not a little black chip soldered onto a motherboard; however, the fundamentals are still the same. Data is permenately burned onto a medium in a pattern correlating to a program or some other form of data.
The older gameboys used Z80 processors and if you look you can find a lot of information on how to modify the original gameboys to run custom roms and custom game cartridges.
Here's a little cool gadget someone put together for an older gameboy:
http://www.semis.demon.co.uk/Gameboy/DsoDemo/DsoDemo.htm
Hope this helped.
Hope this helped.
Thank you. Phew, that page is confusing. a lot of terms I do not understand. It is interesting though. Thank you. I'm also interested in lasers. I want to build my own, but I'm going to have to know a lot mor eabout optics to do so. And a lot of money..I think they cost around $2000+
  • · Replies 24 ·
9K
  • · Replies 17 ·
  • · Replies 26 ·
  • · Replies 38 ·
