An odd sort of symmetry about E=MC^2
  • Context: Undergrad
  • Thread starter Thread starter Dropout
    E=mc^2 Sort Symmetry
The discussion revolves around the implications and interpretations of the equation E=mc², particularly focusing on the relationship between mass and energy, and how relativistic effects influence the perception of mass as velocity increases. Participants explore theoretical aspects and conceptual clarifications related to energy, mass, and motion.
  • Some participants propose that mass can be sacrificed to create energy, suggesting a relationship where energy is viewed as mass in motion.
  • Others argue that the increase in perceived mass at higher velocities is not a true increase in physical mass but rather an effect of relativistic dynamics.
  • A participant introduces the concept of rest mass and rest energy, explaining that energy is derived from the force applied over a distance, which contributes to the mass-energy relationship.
  • There is a mention of the Lorentz Transformation equation, indicating that as speed increases, energy is sacrificed for mass, leading to a complex interplay between mass and energy.
  • One participant attempts to clarify the analogy of pushing a child on a swing to illustrate how the effectiveness of force diminishes as speed increases, without implying an actual increase in mass.
  • Another point raised involves the transformation of particles and the conversion of potential energy to kinetic energy when particles change types, suggesting a dynamic relationship between mass and energy states.
Participants express differing views on the nature of mass and energy in the context of relativity, with no consensus reached on the significance of these relationships or the implications of the discussed concepts.
Some limitations include unclear definitions of mass and energy in the context of relativistic effects, as well as unresolved mathematical interpretations of the relationships discussed.
Dropout
You sacrifice mass to create energy (energy is just mass with a velocity), and the faster mass moves (relativity) the more massive the mass gets, is there some sort of significance to that? I hate riddles.
The question is unclear.
E=MC^2. Destroy mass, create energy. -1 mass +1 energy.
Lorenze Transformation equation. Faster you go (sacrificing energy, propulsion), the more massive mass gets. +1 mass -1 energy.
*brainstorming, but getting absolutely nowhere*
An answer to you riddle.
Energy is force x distance. A stationary mass has rest mass and therefore rest energy. This rest mass used energy to create it - in its structure, force moved through a distance and is stored as potential energy (PE).
When this mass moves it gains kinetic energy (KE).
Now the faster mass moves the more massive it seems to get. Well this is not an increase in physical mass, but is an effect brought about by the effects of force propagating at the speed of light. It's a bit like pushing a child on a swing. As the child moves faster, your hand has less push effect because it moves at the same speed as the swing. This doesn't mean the child's mass has increased, it only means that the effect of the push weakens.
Also when particles change type, ie, big to small, the release of potential energy gives the smaller particle more speed (PE changes to KE).
  • · Replies 26 ·
  • · Replies 16 ·
  • · Replies 17 ·
  • · Replies 55 ·
  • · Replies 62 ·
