Tube/Bar Rigidity: Which Offers Most?
  • Thread starter Thread starter SGT Steel
    Tube
The discussion focuses on the rigidity of grade 316 stainless steel tubes versus solid bars for cantilevered applications involving loads of 10-12kg. It concludes that while solid rods provide greater rigidity than thick-walled tubes, the overall rigidity of a 4-foot long, 3/4-inch diameter cantilevered rod may still be insufficient. The conversation emphasizes the importance of considering wall thickness in tubes and suggests using beam analysis calculators or CAD modeling tools to evaluate different cross-sectional profiles for optimal deflection performance.
  • Understanding of cantilever beam mechanics
  • Familiarity with material properties of grade 316 stainless steel
  • Knowledge of beam analysis calculators and CAD modeling tools
  • Basic concepts of structural rigidity and deflection
  • Research beam analysis calculators for cantilever beams
  • Explore CAD modeling techniques for structural analysis
  • Learn about the effects of wall thickness on tube rigidity
  • Investigate alternative cross-sectional profiles for improved deflection performance
Engineers, structural designers, and anyone involved in selecting materials and designs for cantilevered structures requiring optimal rigidity and minimal deflection.
SGT Steel
Hey guys,
Long time lurker, first time poster! Here is my query...
I need to send a load weighing 10-12kg down two horizontal, parallel, cantilevered, grade 316 stainless steel tubes -- or bars -- each between 3-4 feet in length, 3/4" in diameter, and spaced 85mm apart. What I'd like to know is; in this specific application, would tubes, or bars, offer the most rigidity? If tubes, would a thicker or thinner wall thickness offer the most rigidity?
A tube with a thicker wall is more rigid than a tube of the same outside diameter and material but with a thinner wall, but the solid rod of the same outside diameter and material is more rigid than the thick walled tube. However, I don't consider a 4 foot long 3/4 inch diameter cantilevered rod as being very rigid. Might want to consider a larger diameter depending on your
application.
How much deflection is allowable?
There are many beam analysis calculators on the web or in CAD modellers, or you can do the math yourself for the specific element's cross sectional profile. If you did this, perhaps you would find better solutions than tubular or solid circular cross sections that would solve your deflection issue. But would perhaps be more expensive or require more effort to mount.
It's all a series of trade offs.
13K
  • · Replies 31 ·
9K
29K
12K
11K
