Coriolis Force on a Wheel of radius r spinning at angular velocity
The discussion centers on the Coriolis force acting on a wheel of radius r spinning at angular velocity ω, particularly when positioned in the northern hemisphere. It addresses the misconception that the total Coriolis force on the wheel integrates to zero due to its circular symmetry. Instead, the torque τ generated by the Coriolis force, defined as τ = r' x F.coriolis, does not equal zero, as the forces on different mass elements A and B on the wheel act in opposing directions, creating a net torque. The analysis is further simplified by considering the wheel at the equator, where the Coriolis force can be more clearly defined.
  • Understanding of angular velocity and its implications in rotational dynamics.
  • Familiarity with the concept of the Coriolis force and its mathematical representation.
  • Knowledge of torque and its calculation using vector cross products.
  • Basic principles of physics related to motion in a rotating reference frame.
  • Study the mathematical derivation of the Coriolis force in rotating systems.
  • Explore the effects of the Coriolis force on different objects in motion, particularly at various latitudes.
  • Investigate the implications of torque in rotating systems and how it affects stability and motion.
  • Learn about practical applications of the Coriolis effect in meteorology and oceanography.
Physics students, mechanical engineers, and anyone interested in the dynamics of rotating systems and the effects of the Coriolis force on motion.
kaamlot92
Imagine that we have a wheel spinning with the axis of rotation normal to the Earth's surface. For convenience, let's assume that the wheel is located somewhere in the north hemisphere.
According to the definition of the Coriolis force, every little particle dm of the wheel has a coriolis force in some direction. But if we integrate to get the coriolis force on the whole object, doesn't the integral go to 0 since we are in a circle?
Further, if we consider the torque on the wheel due to the coriolis force, we know that the torque is defined as: τ = r' x F.coriolis . where r' is the vector position of dm relatively to the CM of the wheel.
Since the coriolis force is zero, doesn't it mean that the torque is also zero?
(I know that the answer is no, but why? and where does the torque point...?)
Hello and welcome to PF!
It will be simpler to analyze if the wheel is located at the equator. Then the axis of rotation of the wheel is perpendicular to the axis of rotation of the earth. See attached figure. The axis of rotation of the Earth is represented by the blue vertical arrow and Ω is the rate of rotation of the earth. The wheel is rotating with angular velocity ω.
Consider the elements of mass marked A and B on the wheel. Note that relative to the Earth the velocity of A at this moment is essentially out of the page while B is moving into the page.
What is the direction of the coriolis force on A? On B?
  • · Replies 35 ·
  • · Replies 25 ·
