How does an atomic nucleus have a measurable diameter
The atomic nucleus has a measurable diameter due to the scattering of particles, despite being composed of point-like quarks. The size of a nucleus is defined by the volume that encloses its components, influenced by the strong nuclear force. Measurements are made by observing the scattering patterns of particles fired at the nucleus, allowing scientists to assign a statistical average diameter rather than a precise boundary. This method parallels how we measure the size of larger objects, such as a ball, using light scattering.
  • Understanding of quantum mechanics and particle physics
  • Familiarity with the concept of quarks and the strong nuclear force
  • Knowledge of scattering experiments and their significance in measuring sizes
  • Basic principles of statistical averages in scientific measurements
  • Research particle scattering techniques in nuclear physics
  • Explore the role of the strong nuclear force in atomic structure
  • Study the concept of statistical averages in physical measurements
  • Learn about the properties and behavior of quarks in particle physics
Physicists, students of quantum mechanics, and anyone interested in the fundamental properties of atomic structure and measurement techniques in particle physics.
jaydnul
How is this possible if quarks are point particles?
Think: how can the solar system have a "diameter" ?
You set it as the diameter of a volume that encloses all the solar system objects right?
Same with a nucleus.
Nuclei are not just composed of quarks though - but also of the strong nuclear force.
But what it boils down to is the definition of "size" here.
Clearly a nuclei has a size in the sense of a limited extent - or else how do you tell two nuclei apart.
Clearly the size is not zero since some objects fired at nuclei hit it.
You measure the size of stuff by scattering other stuff off it and making observations about the scattering.
i.e. when you measure the size of a ball, you are scattering light off it (detected by your eyes) and comparing the scatter pattern (image) with that of some standard object (ruler).
Nuclei scatter objects, and from the pattern we can assign a size and thus a diameter.
But bear in mind that the diameter of such small objects is a statistical average rather than a well-defined boundary.
  • · Replies 19 ·
  • · Replies 23 ·
