Ionization Energy: Finding with Charge & Electron Level
The discussion revolves around the concept of ionization energy, specifically how it can be determined when given the charge and electron level of an atom. Participants explore the relationship between these variables and the energy required to remove an electron from an atom.
  • Participants discuss the general nature of ionization energies, noting that they are typically tabulated for ground state electrons. There is mention of the need for experimental values and the influence of atomic state on ionization energy. Some suggest that while tables are useful for multi-electron atoms, there are formulas applicable to simpler cases, such as hydrogen-like ions.
The conversation is ongoing, with participants providing insights into both tabulated values and theoretical formulas for calculating ionization energy. There is recognition of the complexity involved with different atomic structures, and some participants are seeking clarification on specific cases or approximations.
There is an emphasis on the limitations of available data, particularly regarding the states of atoms and the specific conditions under which ionization energies are defined. The discussion highlights the need for clarity on the definitions of charge and electron level in this context.
Twigs
How can you find the Ionization Energy if given the charge and electron level?
In general,ionization energies are tabulated and are given only for the last shell electrons.By charge i think u might mean Z and electron level,the orbital containing the electron which would get expelled.
So,there's no general formula,just experimental values.
Daniel.
It kinda depends on the state of the atom. The ionization energy would be the energy required to remove an electron from the atom and thus ionizing it.
For example, the ionization energy of Helium (in the groundstate) is the difference in energy between it's groundstate and the groundstate of He+.
Tabulated values are for ground state electrons only.
Daniel.
It's certainly true that for atoms with many electrons, you're best off going to a table for these things, but there are formulae for simple atoms and approximations for states that aren't tabulated. For example, hydrogen-like ions (i.e. with one electron) follow:
[tex]E \simeq 13.6\frac{Z^2}{n^2}~eV[/tex]
High-Z two-electron atoms can be approximated with a similar formula:
[tex]E \simeq 13.6\frac{(Z-1)^2}{n^2}~eV[/tex]
There are many analytical/numerical approximations to the energy levels of more complicated atoms, so perhaps you can be more specific about what you're looking for.
[tex]Z^2_eff[/tex] tttttt
