Why doesn't a weak acid/base act as a buffer on its own?
  • Thread starter Thread starter sungholee
    Act Buffer Weak
The discussion revolves around the question of why a weak acid or base cannot function as a buffer on its own. Participants explore the concepts of dissociation, equilibrium, and buffer capacity, focusing on the roles of weak acids, their conjugate bases, and the conditions under which buffering occurs.
  • One participant explains the dissociation of a weak acid and its reaction with added OH-, noting that this leads to more dissociation of HA.
  • The same participant questions why the addition of H+ would not lead to further dissociation of HA, expressing confusion over the role of A- compared to H+.
  • Another participant clarifies that a weak acid alone cannot act as a buffer because it will always partially dissociate into its conjugate base, reaching equilibrium.
  • A different participant introduces the concept of buffer capacity, stating that it is highest at pH = pKa and decreases as the pH moves away from this point.
  • One participant discusses percent ionization, explaining that increasing the concentration of a weak acid leads to a decrease in the percent of acid that dissociates, which may be counterintuitive.
Participants generally agree that a weak acid alone cannot function as a buffer due to its dissociation into a conjugate base. However, there are differing views on the implications of percent ionization and the effectiveness of weak acids in maintaining pH stability.
Some participants mention concepts like buffer capacity and percent ionization, but the discussion does not resolve the complexities of these ideas or their implications for buffering behavior.
sungholee
Hello. I am a high school level student and I had a question about weak acids/bases and why they wouldn't work as a buffer on its own.
If the dissociation of a weak acid is [itex]HA \rightleftharpoons H^{+} + A^{-}[/itex], then when we add [itex]OH^{-}[/itex], it will react with the [itex]H^{+}[/itex] to form water. Because the concentration of the products had been decreased, more [itex]HA[/itex] will dissociate. It's very simple for me upto this point.
But the problem is when we add [itex]H^{+}[/itex], it will react with the [itex]A^{-}[/itex] to form [itex]HA[/itex]. Then, according to Le Chatelier's principle, wouldn't the [itex]HA[/itex] dissociate, because its concentration is greater than the products? What I have been told is that now no more [itex]H^{+}[/itex] can be neutralized because all of the [itex]A^{-}[/itex] have been used up, and that's why we need a salt of the acid, to provide that [itex]A^{-}[/itex]. However, I fail to see why the [itex]A^{-}[/itex] would work differently to [itex]H^{+}[/itex].
Of course, I can pretend I understand it and simply memorise it, but I'll be studying chem in uni so I want to have a strong understanding of the basics.
Thanks.
Chemistry news on Phys.org
Hi, are you asking for example why a weak acid alone would not act as a buffer? ...As opposed to the typical buffer being a weak acid and conjugate base mixture?
In essence, yes I am.
It is a matter of how effective a solution is at maintaining the constant pH. If it resist pH changes we call it a buffer, when it doesn't - we don't. Resistance to pH changes is called a buffer capacity. And it is highest for pH=pKa, goes down the further from the pKa we are.
See derivation and plot here: buffer capacity.
Well, you can't really have a weak acid by itself, as far as I know. It will always partially dissociate into its conjugate base, reaching equilibrium. This is in contrast with a strong acid, which dissociates essentially completely.
I think maybe more related to what you are asking though is something called percent ionization. This is a simple ratio of the concentration of H+ over the concentration of HA (expressed as a percent). Weak acids have small percent ionizations, for example 0.2 M HNO3 would only have a percent ionization of about 4.8% (so like 5 molecules out of 100 dissociate).
Now maybe sort of an unintuitive thing happens, when you increase the concentration of a weak acid, the percent ionization actually decreases. In other words a smaller fraction of the weak acid molecules dissociate. So like a 2.5 M HNO3 solution has a percent ionization of 1.4% (now only like 1 out of 100 dissociate). (I am just getting these vaules from a text) Its still the case that the concentration of H+ is greater for the higher molarity, but the (percent) amount of dissociation that occurs is less.
So in other words the dissociation of HA isn't a linear relationship with concentration, as (if I am reading you right) you might be thinking.
  • · Replies 0 ·
