Register to reply
Exothermic mixing of liquids
by sgstudent
Tags: exothermic, liquids, mixing
Share this thread:
sgstudent
#1
May14-13, 10:45 AM
P: 645
Why is the mixing of ethanol and water exothermic? Because unless there's a reaction I'm thinking by the law of conservation of energy the total energy of the bonds should remain the same before and after. Because considering hydrogen bonds, the total number of bonds is dependent on the 'limiting' number of donors or acceptors right?
So since the limiting doesn't change there can't be more bonds being formed right?
Even if we say that the strength of each H bond changes, wouldn't the strength add up to the same amount again since if some bonds are weaker, others would be stronger?
Thanks for the help :)
Phys.Org News Partner Chemistry news on Phys.org
Ice cream goes Southern, okra extracts may increase shelf-life
The fluorescent fingerprint of plastics
Researchers develop models to study polyelectrolytes, including DNA and RNA
janhaa
#2
May15-13, 02:22 PM
P: 97
I'll try to explain;
Water molecules held together via H-bonds. Pure ethanol is similar, but the clusters of ethanol are smaller. Of course these two solvents are completely miscible.
If these two solvents are mixed, the intermolecular bonding structure changes.
Some water-water H-bonds and ethanol-ethanol H-bonds are broken and some water-ethanol hydrogen bonds are formed.
The process of breaking bonds is endothermic, and the process of making bonds is exothermic.
Because molecules are on the inside of the sphere are involved in more H-bonding than
those on the surface of the sphere, an exothermic mixing dominates.
sgstudent
#3
May16-13, 03:11 AM
P: 645
Quote Quote by janhaa View Post
Hi thanks for the excellent reply :)
But actually, since the total number of H bonds donors and acceptors remain the same shouldn't the total number of H bonds before and after remain the same?
Here's my misconception: A bottle of pure water has a total of 100 H bonds and a separate bottle of ethanol has a total 100 H bonds. When I mix them, the total number of H bonds can only reach 200 H bonds. So shouldn't the mixing not give out energy?
Borek
#4
May16-13, 03:29 AM
Admin
Borek's Avatar
P: 23,536
H-bonds between different molecules aren't equal.
chill_factor
#5
May16-13, 03:00 PM
P: 896
To answer this question in greater detail you need statistical mechanics and water models. The simple answer is that the entropy favors ethanol solvation.
sgstudent
#6
May17-13, 04:15 AM
P: 645
Quote Quote by Borek View Post
That's true, but shouldn't it add up to zero? Say individually A has stronger H bonds than B individually. So compared to A, A-B's H bonds are weaker but compared to B A-B's H bonds are stronger. So shouldn't they add up to zero?
Borek
#7
May17-13, 04:56 AM
Admin
Borek's Avatar
P: 23,536
That would be the case only if the A-B bond energy is an average of A-A and B-B energies, check the math. It doesn't have to.
sgstudent
#8
May19-13, 02:49 AM
P: 645
Oh what do you mean by it doesn't have to? Cos by taking the average it's like if I AA bond energy is 100 and BB 50 then AB would be 75? In this case the total bond strength initially in the
Two components individually would add up to the same amount as the total bond strength in the mixture.
Or is it because AB might not be 75? So if it say 100 then more more energy is given out? Then if AB is say 60 then it would mean that energy is absorbed?
But why does this happen? I was thinking that conservation of energy applied here so the total bond energies should remain the same.
Borek
#9
May19-13, 09:58 AM
Admin
Borek's Avatar
P: 23,536
AB doesn't have be 75. And conservation of energy is exactly the reason why the mixture changes temperature if AB is not 75.
sgstudent
#10
May20-13, 07:18 AM
P: 645
Ohh that clear things up! Actually linking this to Henry's law for a positive deviation the attractive forces in A and B individually must be greater than between AB. So would that mean if A has 100 and B has 50, AB would have to be say 25? So in this case it would be easier to vapourize it?
Register to reply
Related Discussions
Change in Entropy for Mixing of Two Liquids Advanced Physics Homework 1
Exothermic Reactions Chemistry 7
Formula for mixing liquids of different temperatures? General Physics 4
Endo or Exothermic? Biology, Chemistry & Other Homework 2
Why exactly is this exothermic Biology, Chemistry & Other Homework 1
