Finding the Distance for a Zero Electric Field at a Corner of a Square
The problem involves determining the position of a third charge in relation to two existing charges placed at the corners of a square, such that the electric field at one corner is zero. The subject area is electrostatics, focusing on electric fields generated by point charges.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss various methods to calculate the electric field at point A, including the use of components and angles. There are attempts to verify calculations and check for errors in arithmetic and unit conversions.
Some participants are exploring different interpretations of the angle and its implications for the direction of the electric field. There is a recognition of potential issues with rounding and the format of answers required by the problem. Guidance has been offered regarding checking calculations and ensuring the correct representation of angles.
Participants mention constraints related to homework submission, such as formatting requirements and significant figures. There is uncertainty about the correctness of the calculated values and the potential for minor errors to affect the outcome.
thercias
Two tiny objects with equal charges of 63.0 µC are placed at two corners of a square with sides of 0.260 m, as shown. How far above and to the left of the corner of the square labeled A would you place a third small object with the same charge so that the electric field is zero at A?
E = KQ/r^2
I first solved for E net on point A. My values were
Enetx = 2.962 x 10^6
Enety = 1.13 x 10^7
Magnitude of Etotal = 1.17 x 10^7
angle formed : 75.3 degrees
Now I tried two alternate solutions, but in the end I got the wrong answer still for both tries.
E = kq/r^2
r = sqrt(kq/E)
r = sqrt(k(63e-6)/1.17e6)
r=0.22m
dx=0.22cos75.3=0.0558
dy=0.22sin75.3=0.213
That one was wrong, so I tried finding the value of r using the components of the electric field
rx= sqrt(k(63e-6)/2.962e6)
ry=sqrt(k(63e-6)/1.13e7)
rx =0.43m
ry=0.22m
still wrong, i need help because I'm not sure what I'm doing wrong.
The first method is the one I'd have used.
Check units and arithmetic.
Enety = 1.13 x 10^7
... that angle looks bad - the resulting field should point up and to the left, so the angle from the +x axis will be bigger than 90deg.
I don't see how you got the x and y components either.
Enety = 1.13 x 10^7
I ussed the equation
E1 = kq/r^2
= kq/0.26^2
= 8.378e6 going south
E2 = kq/(0.26^2+0.26^2)
= 4.189e6 going south and to the right
E2cos45 = 2.96e6 (to the right)
E2sin45 = 2.96e6 (south)
therefore Eynet = 1.13e7
Exnet = 2.96e6
Magnitude sqrt ((2.962e6)^2+(1.13e7)^2)
=1.17e7
angle = tan inverse (Ey/Ex)
= 75.3 degrees
So the electric field will go in the opposite direction of this to cancel out of the third charge.
I might be doing something wrong, but I don't know what it is. This is due in 42 minutes, if anyone can check my values quickly or if there's a logic error that I missed i'd appreciate it.
How do you kow it's wrong - is it computer moderated?
If so - careful with rounding - make sure you have entered the correct format and units.
i.e. does it want an angle? If so - in degrees or radians?
How many sig fig is it expecting?
You realize that 75.361° is clockwise from the -x axis - if they want to measure angles anticlockwise from the +x then this will be marked wrong. Also notice that it rounds to 75.4 not 75.3.
You got to check the details.
I'm getting the same angle and field strength as you, but a different distance, using k=8.99e9(SIU)
[edit]nope - I just forgot to invert.
I'm getting the same as you - check for fiddly stuff.
edit: nevermind, thanks simon
Ok this helped me out. I guess I just wasn't being detailed with my calculations, it was off by 0.02 and that was enough to make it wrong on the computer. Thanks so much!
  • · Replies 16 ·
