Worded Problem, Probability Density, quantum mechanics
The discussion revolves around a probability density problem in the context of quantum mechanics, specifically related to a speedometer needle that can rest at either 0 or π. Participants are exploring the implications of the problem statement and the characteristics of probability density functions.
  • Some participants suggest that the probability density function could be uniform, while others question the necessity of the function dropping to zero at the endpoints. There is also discussion about the implications of the problem statement regarding the likelihood of the needle resting at specific points.
The discussion is active, with participants providing insights into the nature of probability density functions and questioning the original problem's wording. There is an exploration of different interpretations of the problem, particularly regarding the uniform distribution and its properties.
Participants note potential discrepancies in the problem statement as it was relayed, which may affect the interpretation of the probability density function. There is also mention of the top-hat distribution and its relevance to the problem, alongside uncertainty about the definitions of certain terms.
Cogswell
The needle on a broken car speedometer is free to swing and bounces off perfectly off the pins at either end, so that if you gave it a flick it's equally likely to come to rest at 0 and ## \pi ##
What is the probability density, ## p(x) ##?
[tex]\int^{\pi}_{0} p(x) dx = \int^{\pi}_{0} |\Psi (x,t)|^2 dx = 1[/tex]
This may sound really dumb but I was thinking that since that it's equally likely to be from anywhere between 0 and pi, then it'll just be a straight horizontal line, p(x) = 1.
But since it has to be normalised from 0 to pi, then p(x) will just be 1/pi.
But that didn't seem right because it had to drop off to 0 at x=0 and x=pi so I was thinking of a sine curve, and maybe p(x) = sin(x)
How does that work though? It says it's equally likely to land anywhere from 0 to pi, but with a sine curve it's obvious that it'll have a way higher chance of landing in the middle...
Why do you need ##p(x=0)=0## and ##p(x=\pi)=0## ?
Note: if p(x) is a probability density function, then $$P(a<x<b)=\int_a^bp(x)dx$$
Oh sorry I was thinking of a gaussian curve and how it drops off to zero at infinity.
So I was right about ## p(x) = \dfrac{1}{\pi} ##??
Then if I evaluate the integral ## \displaystyle P(a < x < b) = \int^{\pi}_{0} \dfrac{1}{\pi} dx = 1 ##
If I evaluate it from ## \displaystyle \theta ## to ## d \theta ## I'll always get the same number, no matter what theta is: ## \displaystyle \int^{\theta + d \theta}_{\theta} \dfrac{1}{\pi} dx = Constant ##
It's the only function that I can think of that has the same probability no matter what theta is.
OK you are having a bit of trouble having confidence in your deductions...
The top-hat distribution from x=0 to x=L would be: ##p(x)=\frac{1}{L}( h(x)-h(x-L) )## where ##h(x)## is the Heaviside step. Notice that the requirement ##\int_{-infty}^\infty p(x)dx## means that##P(0<x<L)=1## and so does not need the points x=0 and x=L to be included?
I can write that out:$$p(x)=\left \{ \begin{array}{ll}
\frac{1}{L} & : \; 0<x<L\\
0 & : \; x\leq 0\\
0 & : \; x\geq L
\end{array} \right . $$
... but does it matter to the statistics if we do include 0 and L in the first inequalities?
(note: if you look up the Heaviside function, you'll see different people use different values at the limits.)
The question says that the probability of finding the needle in any arbitrarily small region inside 0≤x≤π is a constant - so far so good - and, intuitively, you'd figure that the probability of finding the needle exactly at x=0 or x=π would be zero. Does the top-hat distribution give you that?
Incidentally: since you mentioned QM, you could check to see if ##\psi(x)=\frac{1}{\sqrt{L}}( h(x)-h(x-L) )## is a solution to the Scrödinger equation ;)
Is the problem statement exactly as it was given to you? I ask because as you typed it, it doesn't say that the needle is likely to be anywhere between 0 and ##\pi##; it said it's equally likely to be 0 or ##\pi##.
I'm pretty sure I typed it out exactly as the book had it.
I took a photo of the original problem (In the book Quantum Mechanics Second Edition by David J Griffiths)
It's near the very start of the book so I'm presuming it doesn't require that much knowledge about quantum mechanics.
0 & : \; x\leq 0\\
0 & : \; x\geq L
Sorry I don't know what a top-hat distribution is, nor what a Heaviside step. (I quickly googled it a top-hat distribution and I see that it would be the shape I need for equal probability.)
I get that:
0 & : \; x\leq 0\\
0 & : \; x\geq L
where I presume L is ## \pi ## in this case.
I don't know if the top hat distribution would give me 0 for x=0 and x=pi, we haven't needed to study it for this course.
From the diagrams it seems like it'll give me 1/pi for when x=0 and x=pi, because it looks like the infinite square well. But does it really matter what x=0 and x=pi are?
I guess the speedometer needle angle can never be zero because there's a pin there that stops it, and same with the angle pi.
But I don't quite get the top hat equation is. I google it and can't seem to find a general form of it.
Oh, I see you left out a couple of words when you typed up the statement that completely change the meaning.
Cogswell said:
vela said:
Is the problem statement exactly as it was given to you? I ask because as you typed it, it doesn't say that the needle is likely to be anywhere between 0 and π; it said it's equally likely to be 0 or π.
... you didn;t type it out the way your attached picture tells it - but never mind, I followed the attachment and not what you wrote.
But you do know how to compute a probability from a probability density function don't you?
Anyway - you have seen it before - probably just not under that name.
Unless... where abouts in your education are you at right now?
How did you compute that?
You mean p(x)? - um - no it's pretty much the opposite of a square well ... very little like an infinite one. Did you try plotting it?
That was my question to you ;)
Note: you are the one who brought it up.
<puzzled> I gave you a general form of it - it's the piece-wise function with the L in it. Really generally, a uniform pdf : a<x<b is $$p(x) = \frac{1}{b-a}[h(x-a)-h(x-b)]$$ where h(x) is the Heaviside step function.
I googled for "top hat probability density function" and came up with lots of examples, i.e.
http://wiki.answers.com/Q/What_is_Top-Hat_horizontal_distribution
http://www.jhu.edu/virtlab/course-info/ei/notes/uncertainty_notes.pdf (p4)
http://www.pha.jhu.edu/~neufeld/numerical/lecturenotes5.pdf (slide 104)
It's one of the first distributions you get taught studying probability - the discrete version is the distribution obeyed by dice. It's one of the simplest around: try "uniform distribution":
http://en.wikipedia.org/wiki/Uniform_distribution_(continuous)
That help?
But you don't need to know the name ... just the maths.
It is looking almost like you don't understand what a probability density function does.
Oh sorry I thought the hint part wasn't that important and that the all I needed in the question was the main part.
I'm guessing it's just the area under the curve of the probability density function, ##\displaystyle P(a \le x \le b) = \int_{a}^{b} p(x)dx ##
I don't think I've seen it before, We've only studied the basics of quantum mechanics.
I'm studyng at Otago University, New Zealand.
Second year physics (PHSI231), doing a bit of classical, quantum and thermal physics.
I didn't really compute it, I just looked at the pictures of what a top-hat distribution looked like.
Oh yea, like the opposite of an infinite square well.
How would you plot it, something like this?
Code:
     ______
_____|     |_____
I'm guessing since the integral I used to calculate it ## \displaystyle \int_{0}^{\pi}p(x) dx = 1 ## then it would have to include 0 and pi, because they are the bounds of the integral and so p(x) = 1/pi and also p(0) = 1/pi
That help?
Ah that Wikipedia page helped me heaps, thanks. It didn't show up when I googled stuff but I guess I just didn't know what to search.
So then the probability density would just be the top hat distribution (I don't really understand what a Heaviside step function is, and the wikipedia article on it is quite confusing for me):
$$ p(x) = \frac{1}{\pi}[h(x)-h(x-\pi)] $$
\frac{1}{\pi} & : \; 0 \le x \le \pi \\
0 & : \; x < 0\\
0 & : \; x > \pi
I presume this is what I want? It satisfies all the conditions,
[tex]\displaystyle \int_{0}^{\pi} p(x) dx = 1[/tex]
[tex]\displaystyle P(0 \le \theta < d \theta \le \pi) = \int_{\theta}^{\theta + d \theta} p(x) dx = \text{A Constant}[/tex]
Haha sorry, I'm not really 'with it' when it comes to understanding physics concepts. I'm more of a Math Major. I do get that the area under the probability density function from a to b tells us that's the probability of finding the particle within that region. And that the wave function squared gives us a probability density function.
That makes sense.
At level 2 you are expected top bring all your learning to bear on the course and not just the stuff specifically mentioned in the lectures. You are expected to have a core knowledge base to build on. What has happened here is that a prior familiarity with probability and statistics (part of mathematics), that you do not possess, has been expected of you.
In New Zealand - you get introduced to probability and statistics as part of the core math course at secondary school ... you will have met probabilities with dice by year 9.
You will have learned that the probability of a particular outcome is (by definition) the number of ways to get that outcome divided by the number of ways to get anything else.
When you specialize - you take a calculus or a statistics track in maths, but the core curriculum for both tracks includes basic probability and statistics - so you should have seen at least the normal distribution, and, by extension, continuous probability distributions, before you left secondary school. The continuous uniform distribution may not have been taught in the calculus track - that would depend on the school.
Otago does not require a statistics paper at stage 1 as a prerequisite for stage 2 QM as the paper does not require an understanding of stats above year 12 - but it is advisable if you did not take the stats track at secondary level.
So it is possible that you have done no probability or statistics since graduating secondary school.
If this is the case - then you should add a statistics paper to your course.
You say you have "got" the basic math for probability density functions but you had trouble with basic questions involving that knowledge... you "guess"ed about how to get a probability from a density function for eg, and were confused about what was part of physics and what part of math, you appeared to have trouble picturing the shapes of functions, and you don't seem to recall secondary math
I suspect you are used to the "applying formulas" part of math - when what you need is the "understanding" part.
Seeing you are at level 2 physics, then you probably have not met the Heaviside function in so many words yet - another function you will see a lot of but have yet to meet will be the Dirac delta function ##\delta(x)## - though you have probably seen the Kronecker delta ##\delta_{jk}##.
The Heaviside function is simply a way of writing a piece-wise function on one line ...
h(x)=0: x<0 and h(x)=1: x>0 ... what happens at x=0 depends on who you ask.
I usually put h(0)=0, some people put h(0)=1/2 or 1. For the purposes above it doesn't matter.
You seem to have got it in the end though.
It shouldn't be this hard for you - this is math, not physics, and you say you are "math oriented".
Simon Bridge said:
That makes sense.
I remember being introduced to basic probability with coins and dice but not as much statistics. We only did like the mean, median and mode sort of stuff in High School.
I specialised in calculus, not statistics and never saw a normal distribution in High School. Right now I am taking a first year statistics paper, and we're only getting into the basics of a normal distribution.
You seem to know quite a lot about NZ and Otago university, which is weird. Not many people know much about New Zealand.
I am still quite confused about understanding physics concepts so that's probably why it seems like I'm lost.
Starting from the top, the whole concept of a particle not being in a particular location is new and surprising to me. I always thought Laplace's[/PLAIN] Demon was sort of true and that if you measure the precise location and momentum of every particle you can predict the past present and future. Then they introduce this whole thing called Heisenberg's uncertainty principle to me and then everything's just changed.
And then there's the whole thing of a potential and a stray particle. Do they mean a particle as in a proton (Hydrogen ion)?
I'm not confused about shapes of functions (at least not continuous ones). In calculus we've only ever dealt with continuous functions and so the top hat distribution is still a bit weird for me.
I guess the NZ High School education system isn't that great at preparing you for university. I got straight into second year physics because of my 'strong' mathematics background (and I took a basic first year university maths paper and got A+).
Nope, never heard of the Heaviside function, but that (how you explained it) makes it so much simpler. I don't know why the Wikipedia article on it is so much more confusing to understand.
This is basically what I'd come to suspect.
More than you'd suspect - Kiwis have been getting around and seem to have a pretty good international reputation.
I am very familiar with NZ education system, having works in it for decades across all the levels.
From what you'g got now, you should be able to cope with the maths of continuous probability distributions - bear in mind that p(x) can be any function at all so long as the total area under the graph can be normalized.
It's something everyone has to go through ... you get used to it.
The definition of a particle is deliberately left vague at this stage - just think of it as building upon what you already know about classical particles: a purely abstract idea which has application in the real world.
A good RL example of a particle is an electron.
The idea applies to any object whose internal structure and size does not affect it's dynamics.
The top-hat distribution is continuous in the sense that you saw in calc class.
Oh OK - that would explain a lot then. People who get the accelerated courses tend to struggle.
The stage 1 papers mostly concentrate on going over everything you were supposed to get by the end of secondary school ... makes sure everyone is on the same page. This is really great for solidifying what you already know and fills in a lot of gaps where you may have forgotten something or the teachers ran out of time or something.
You need a good crash course then - you should try to get hold of NZQA primer books - the sorts of things that prepare you for external exams. The NZQA website has past exam papers and exemplars that can make a useful study guide.
http://www.nzqa.govt.nz/ncea/assessment/search.do?query=mathematics&view=exams&level=03
Wikipedia math articles tend to be marginal in usefulness because they have been written by mathematicians who care more about being mathematically rigorous than being easy for a novice to understand.
Don't let the names of things throw you - focus on what the thing actually is.
I'm trying to get A+ in this paper and it seems like it's near impossible! I have 2 weeks before my exams and I'm studying this at least 3 hours a day for this and reading the books and going through the questions but I'm still lacking a lot of base knowledge.
I think the best thing is to go through more questions so I understand how to do them.
Okay, so I have answered the first part of the question, which is:
$$p(\theta)=\left \{ \begin{array}{ll}
\frac{1}{\pi} & \text{for} \; 0 \le \theta \le \pi \\
0 & \text{for} \; \theta < 0\\
0 & \text{for} \; \theta > \pi
The second part asks "Compute ## < \theta > ##, ## < \theta^2 > ##, and ## < \sigma > ##, for this distribution"
Exactly as is, no hints or anything.
So I know that ## | \Psi (x,t) |^2 = p(x) ##Therefore: ## \Psi (\theta , t)=\left \{ \begin{array}{ll}
\frac{1}{\sqrt{\pi}} & \text{for} \; 0 \le \theta \le \pi \\
\end{array} \right . ##
The expectation value is just:
[tex]< \theta > = \displaystyle \int^{\pi}_{0} \Psi (\theta , t)^* (\theta) \Psi (\theta , t) d \theta[/tex]
[tex]< \theta > = \displaystyle \int^{\pi}_{0} \frac{1}{\sqrt{\pi}} ( \theta) \frac{1}{\sqrt{\pi}} d \theta[/tex][tex]< \theta > = \displaystyle \frac{1}{\pi} \int^{\pi}_{0} \theta d \theta[/tex]
[tex]< \theta > = \displaystyle \frac{1}{\pi} \left[ \dfrac{\theta ^2}{2} \right]^{\pi}_{0}[/tex]
[tex]< \theta > = \dfrac{\pi}{2}[/tex]
This seems correct, because that's the center of probability distribution.
And then, for the expectation value of ## \theta ^2 ##
[tex]< \theta ^2 > = \displaystyle \int^{\pi}_{0} \frac{1}{\sqrt{\pi}} ( \theta ^2) \frac{1}{\sqrt{\pi}} d \theta[/tex]
[tex]< \theta ^2 > = \dfrac{\pi ^2}{3}[/tex]
And I know that ## \sigma = \sqrt{< \theta ^2> - < \theta >^2} ## so I can just easil work ou sigma from that.
Is that right?The last question then asks for me to compute ##< \sin ( \theta )>##, ## < \cos ( \theta )> ## and ##< \cos ^2 ( \theta ) ##.
It should be fairly simple right, sort of like above, and for the ## \cos^2 ## I just use the trig identity to simplify it so I can integrate it?
Doing good so far.
Just a niggle - in the very first line of math, the limits of the integral should be all space ... you got specific in the next line.
You are on the right track - notice that the sine and cosine parts are y and x components of the needle's arc?
For full marks you may want to comment on if <sinA> bears any relation to the <A> etc.
There is nothing wrong with just looking up such simple integrals.
Simon Bridge said:
Doing good so far.
What do you mean, so I should integrate from negative infinity to infinity? But then how would I write the integral, since the wave function is a piecewise function? Something like this?
[tex]\displaystyle \int_{- \infty}^{0} 0^2 \theta d \theta + \int_{0}^{\pi} \dfrac{\theta}{\sqrt{\pi}^2}d \theta + \int_{\pi}^{\infty} 0^2 \theta d \theta[/tex]I think the sine and cosine things relate to the next question in the book:
We consider the same device as the previous problem, but this time we are interested in the x-coordinate of the needle point - that is, the "shadow" or "projection" of the needle on the horizontal line.
What is the probability density p(x)?
Graph p(x) as a function of x, from -2r to +2r, where r is the length of the needle. Make sure the total probability is 1. Hint: p(x) dx is the probability that the projection lies between x and (x + dx). You know (from problem 1.11) the probability that ## \theta ## is in a given range; the question is, what interval dx corresponds to the interval ## d \theta ##
So for this one, the probability density would be like a cosine curve?
Code:
-----|----|----|----x
    -2r   |    2r
          y
(Sorry for the horrible cosine curve drawn by the code tags, but you know what a cosine curve looks like)
So to normalise it, I'd need:
[tex]\displaystyle \int^{2r}_{-2r} Acos(\dfrac{\pi x}{2r}) dx = 1[/tex]
Although I don't know what to do with the hint...
The first line is fine the way you wrote it - but the limits should, technically, be all space. The second line is fine to follow.
After all, you started from the definition of the expectation value ... then you observe that some sub-areas are zero.
But, like I said, it's just a niggle.That hint is a little bit like how you convert between polar and rectangular coordinates.
You know ##p(\theta)## of finding the needle between ##\theta## and ##\theta+d\theta## ... can you relate that range to x and x+dx?
The arclength in that range, for eg, ##rd\theta## for instance.
Oh right I get it, because I wrote ## \Psi (x,t) ## in the first integral and the wave function is always from negative infinity to infinity. And then I changed to the specific piece of the wave function which had a different boundary, limited from 0 to pi.
So the x position is related to theta by:
## x = \cos \left(\dfrac{\pi \theta}{2r} \right) ## for ## 0 \le \theta \le \pi ##
## dx = - \dfrac{\pi}{2r} \sin \left(\dfrac{\pi \theta}{2r} \right) d \theta ##
What do I need to do with these now?
Integrate?
## \displaystyle \int_{x}^{x + dx} A \cos \left(\dfrac{\pi \theta}{2r} \right) dx ##
In fact ##\Psi(x,t)## was overkill - you are only worried about the space part.
Note: everything inside a trig function should have the same dimensions as angle.
What you are trying to do is relate ##\psi(x)## with what you know about ##\psi(\theta)##.
I'd start by sketching it out.
Oh right I think the 2r part is supposed to be outside of the cosine function.
So something like this: ## x = r \cos( \theta) ##
And so ## \theta = \arccos \left( \dfrac{x}{r} \right) ##
So when the angle is zero, the needle's x position is r away, and when the angle is 90 degrees then the needle's x position is at 0.
And then ## dx = -r \sin (\theta) d \theta ##
Now do I replace ## \theta ## with x for the probability density?
\frac{1}{r} & : \; 0< \theta <r \\
0 & : \; \theta \leq 0\\
0 & : \; \theta \geq r
Am I headed in the right direction?
Um ... I don't think so.
It looks like you have started guessing random stuff now.
Did you sketch out the situation?
Concentrate: You know that ##x=r\cos\theta## so ##\langle x \rangle = \langle r\cos\theta \rangle## and you have ##\psi(\theta)##.
(you should beable to guess it anyway - knowing ##\langle\theta\rangle##.)
To change ##p(\theta)## into ##p(x)## you use ##\theta=\arccos(x/r)## ... everywhere you see a ##\theta## in ##p(\theta)## you put an ##\arccos(x/r)## ... then simplify.
  • · Replies 18 ·
