Electric field-Charge inside a metallic shell
  • Context: Undergrad
  • Thread starter Thread starter Vibhor
    Electric Shell
The discussion revolves around the behavior of electric fields in the context of a spherical metallic shell with a point charge at its center and an external charge. Participants explore concepts related to induced charges, the nature of electric fields inside and outside the shell, and the implications of these arrangements on the forces experienced by charges.
  • Some participants assert that the induced charges on the metallic shell rearrange to cancel the external electric field, leading to a zero electric field within the conducting shell.
  • There is uncertainty regarding whether the external electric field refers to the field due to both charges q1 and q2 or only q2.
  • One participant questions the assertion that the electric field at the center of the shell is zero, suggesting that the effect of the external charge q2 on q1 should be considered.
  • Another participant clarifies that the electric field due to q2 is zero inside the shell, while the electric field due to q1 is not zero.
  • Some participants propose that the electric field is zero at the center of the shell due to symmetry of charge distribution or because the shell is an equipotential surface.
  • One participant explains that the electric field in the material of the conductor is zero, but the field in the cavity where q1 resides is not zero.
  • There is a suggestion that the induced charges rearrange to cancel the electric fields produced by both q1 and q2 within the material of the conducting shell.
Participants express differing views on the role of charges q1 and q2 in influencing the electric field within the shell. While some agree that the induced charges cancel the external field, there is no consensus on the interpretation of "external field" and the implications for the electric field at the center of the shell.
The discussion includes various assumptions about charge distributions and the effects of external fields, which are not fully resolved. The implications of these assumptions on the electric field behavior are also debated.
Vibhor
I am having few doubts while studying electric field which i am putting here
Suppose there is a spherical metallic shell with point charge q1 at the center and q2 charge outside the sphere in space ...
1) Now what I have have read in this forum and on other places is that the induced charges rearrange themselves in such a way that they cancel the external electric field such that the electric field within the conducting shell is zero .
Now ,when we say external electric field ...do we mean electric field due to q2 as well as q1 ?
2) The force experienced by charge q1 placed at the center of the shell will be zero .
I am not sure about the reason behind this .The force can be zero only when the electric field at the center of the shell is zero .
Why is electric field zero at the center of the shell .What about the effect of outside charge q2 on q1 ?
I would be highly grateful if somebody could help me in clearing the concepts .
Thanks
That would be q2 in this case - the statement is a general consequence of having mobile charges in the conductor. The effect of any electric field anywhere on a conductor is to move the charges around. At static-equilibrium the net field inside the conducting region is zero. In this case, that would be the field inside the physical metal of the shell.
A consequence if this is that the field inside the cavity is also zero - you should be able to see this by considering the charge distribution required for the field to be non-zero somewhere in the cavity.
Yes.
Why is electric field zero at the center of the shell? What about the effect of outside charge q2 on q1 ?
The answer to both questions is the same: the charge on the surface of the shell has rearranged to cancel it out.
The electric field due to q2, everywhere inside the shell, is zero.
But the electric field due to q1 inside the shell is not zero.
Hello Simon
Thanks for responding.Please reconsider your statement that by external field we mean field due to only the outside charge q2 .Why wouldn't q1 not play any role in inducing charges within metal of the shell ?
What if q2 hadnt been there?In that case don't you feel that induced charges in the metal would rearrange themselves so as to cancel the effect of electric field produced by central charge q1.
The charge q1 will induce -q1 negative charge on the inside surface of the shell and hence +q1 charge on the outside surface of the shell .
Now the electric field is not zero within the shell .
Please give me the reason why electric field is zero at the center of the shell .One reason I got was due to symmetry of charge distribution on the inside surface of the shell.
Another reason I got was because the shell is an equipotential surface .
Which of these reasons is correct ? or is there some other concept involved .
Thanks
The electric field in the material of the conductor vanishes. If you have a spherical metallic ball and carve out a large concentric spherical cavity within the ball so that you end up with a thin metallic shell with an inner and outer surface and a large concentric spherical hollow cavity below the inner surface, and place a point charge in the cavity, then you will end up with what you are talking about, sort of like this: http://s3.amazonaws.com/answer-board-image/74fe503d-8d9d-47b9-a467-9674312e7cdd.gif (replace the insulator with a point charge)
So the electric field is zero in the material of the conductor, which is the region in between the inner and outer surface of the metallic shell. It is not zero in the spherical cavity where the point charge resides because this is not part of the material of the conductor. If you assume ##E = 0## in the cavity then by Gauss's law
##\oint E\cdot dA = 0 ## which implies ##Q_{\text{enclosed}} = 0## which is a contradiction because there is a point charge residing in the cavity.
What happens is that the presence of the point charge in the cavity causes the charges in the conductor to arrange themselves along the inner and outer surface of the associated metallic shell so as to make the field due to the point charge exactly cancel with the field due to the charges of the conductor within the material of the conductor i.e. in between the inner and outer surface. However, there is no implication that the field in the cavity must then vanish.
What is true is that the field due to the point charge outside of the conductor will not be able to penetrate the shell i.e. there will be no field due to the external point charge anywhere within the conductor nor in the cavity: the field will be killed off by the charges on the outer surface of the conductor. Similarly, the field due to the point charge in the cavity will also vanish for all points exterior to the cavity because it will be killed off by the charges on the inner surface of the conductor.
You asked what was meant by the "external field" in the statement:
... charge q1 would produce a non-zero electric field inside the shell, but charge q2 would not.
Therefore the "external field" in the statement under discussion is that produced by q2 and not that produced by q1.
Please give me the reason why electric field is zero at the center of the shell.
The field at the center of the shell in the setup you described is not defined as there is a charge q1 at the center of the shell. Please reread my original reply - you will find the words "due to" get used. I never said the field inside the shell you described would be zero.
It is the field due to q2 that is zero.
The field inside the cavity is that due to q1 alone.
The two reasons you have found are both correct.
Thanks WannabeNewton and Simon
If I rephrase my statement as the induced charges rearrange themselves in such a way that they cancel the electric field produced by q1 and q2 such that the electric field within the material of conducting shell is zero .
Am I right ?
Am I right ?
Yes, the charges in the material of the conductor will move around until the net electric field within the material of the conductor is zero.
Yep - specify "conductor" though - the effect is not limited to conducting shells.
The original statement was regarding a special case that there was no charge enclosed in the shell.
My first doubt is cleared.
Second thing I want to understand is how is force experienced by central charge q1 zero despite the presence of outside charge q2 ?
Is it because of spherically symmetrical charge distribution -q1 on the inner surface of the shell or because the shell is equipotential or both ? Please explain the correct reasoning .
For the point charge outside the conductor, note that the only way this external charge can exert a force on the point charge in the carved out cavity within the conductor is if the electric field lines of the external charge penetrate the material of the conductor so as to reach the charge in the cavity but if it penetrates the material of the conductor then there is a non-vanishing electric field in the material of the conductor which we know cannot be true in the electrostatic configuration.
Fine .This explains how external charge q2 doesn't affect the central charge q1.
But why and how is electric field at the center of the shell zero ,thus zero force on charge q1 ?
The electric field at the center of the shell is not zero as Simon already pointed out! There is a non-vanishing electric field in the cavity that the point charge resides in but this doesn't mean the point charge feels a force because it is the one creating the electric field in the cavity.
Fine . Things are getting cleared but more doubts are creeping in .
What about the fact that the field at any point in space is determined by the distribution of all the charges in the space .Right?
The central charge is being acted on by all charges in space, including the charge induced on the inner and outer part of the shell and the charge outside the shell.
What if the question asked is (assuming charge q2 is at some distance towards right of the shell )
The force on the central charge due to the shell is
1) towards left
2) towards right
3) upward
4) zero
My reasoning says it should be 4)zero but the correct answer is 2)towards right.
This question was asked in a test I appeared.
Sketch the situation and draw in the induced charges - what do you observe.
-q1 charge is induced on the inner surface of the shell whereas +q1 on the outer surface of the shell .-q1 charge is uniformly distributed on the inner surface .Outer surface will not be uniformly distributed due to influence of charge q2 .
Is it correct?
Kinda - did you sketch the situation?
You should have more detail - roughly where do the induced positive and negative charges on the outside of the shell lie in relation to the position of +q2?
  • · Replies 19 ·
  • · Replies 16 ·
