At which distance can you see Saturn's ring with a naked eye?
  • Context: High School
  • Thread starter Thread starter Tiger Blood
    Eye Ring
The discussion centers around the visibility of Saturn's rings with the naked eye, exploring the distance at which they can be discerned. Participants consider various factors affecting visibility, including distance, angular resolution, and observational conditions.
  • Some participants suggest that Saturn's rings may not be visible from Mars, questioning the distance required for visibility.
  • A claim is made that approximately 300 million kilometers is the distance at which Saturn's rings could be discerned, though this is contested.
  • One participant proposes that visibility depends on the angle of inclination of the ring plane relative to the observer's line of sight.
  • Another participant mentions that a 25x telescope is needed to resolve the rings, implying that Saturn must be significantly closer for the rings to be visible to the naked eye.
  • Disagreement arises regarding the calculations related to magnification and distance, with some participants challenging the methods used to derive the visibility distance.
  • Several participants discuss the angular resolution of the human eye and how it relates to the ability to see Saturn's rings, suggesting that a distance of around 200 million kilometers might allow for some structural visibility.
  • One participant shares personal observational experiences with binoculars, noting that Saturn appeared irregular rather than circular, indicating difficulty in discerning the rings without prior knowledge.
  • Another participant calculates the necessary distance to resolve the rings based on angular separation, suggesting a much closer distance of approximately 24 million kilometers.
Participants express multiple competing views on the distance required to see Saturn's rings, with no consensus reached on the exact figures or methods of calculation. Disagreements regarding the interpretation of magnification and angular resolution persist throughout the discussion.
Limitations in the discussion include varying assumptions about observational conditions, the definitions of visibility, and the mathematical steps involved in deriving distances. The discussion reflects a range of perspectives without resolving these complexities.
Tiger Blood
At which distance can you see Saturn's ring with a naked eye? I guess you would not be able to see it from Mars?
Astronomy news on Phys.org
Roughly 300,000,000 kilometers, or about 22% of its current distance. The rings of Saturn would not always be discernable even if it were in the orbit occupied by Mars.
i'm assuming that this is b/c 1) when the Sun is more or less directly between Mars and Earth, Mars is much farther than 300,000,000km away from us, and 2) even if Saturn were 300,000,000km away or less, the visibility of its rings would still depend on the angle of inclination of the ring plane with respect to the line of sight of the ground observer?
Chronos, how did you come about that number? Just curious, thanks.
It takes about a 25x telescope to resolve the rings of Saturn. For Saturn to appear 25 time larger to the unaided eye, it must be 4.67 times closer (inverse square law - 2^n = 25; n = 4.67). The average distance to Saturn is about 1.4 billion kilometers (1.2 minimum, 1.67 maximum). 1.4 billion / 4.67 is about 300 million.
Completely wrong!
You are taking logarithm and calling it square root. And you should not have even root in the first place, because telescope magnification is quoted as linear.
Saturn with rings is about 46 arc seconds wide at opposition closest approach to Earth. So at 40x magnification, or approaching to 0.25 AU, Saturn´s rings will span the width of full Moon.
But you can see many details on Moon. How much do you need to magnify Saturn to detect that it is not a point?
The angular resolution of the eye is somewhere between 1 and 4 arcminutes. If Saturn's rings appear under an angle of 4 arc minutes, it could be possible to see some structure (basically a deviation from a round object). To get this, we have to be 6 times closer to Saturn, which corresponds to a distance of ~1.3 AU or ~200 million km.
A magnification of x2 - x4 should do. But the hard question is what "see Saturn's rings" translates into. At the magnification Chronos suggested (x25) Saturn would be quite small but most people should be able to clearly see the rings. If the nights (I live at 60 deg north) wasn't already much to bright and Saturn so close to the horizon I'd be tempted to go out and try this with one of my telescopes and my 7x35mm, 10x50mm and 15x70mm binoculars.
ETA: I watched Saturn in binos before but it has been several years since last time so the memory is not fresh.
snorkack said:
Completely wrong!
Under the square root law, the coversion factor is n^2, not 2^n (I plead dyslexia). At a distance of 1.4 billion km, Saturn would need to be at a distance of 280 million km, not 300 million km to magnify it by 25x.
I use a cheap pair of 10x50's in an area with a Bortle scale 6ish sky and it appears not circular (certainly irregular). If I didn't know it was Saturn I'm not sure what I would infer. (saturn is around a 40 degree altitude at my latitude during local time 22:00)
You missed the important part of his message, resolution is inverse linear with distance not inverse square distance. To get 25 times more resolution you need to be 25 times closer or 56 million km using your values.
I disregarded my previous statement and utilized a gap in the clouds to set up my 15x70mm binos on a tripod. Bad seeing due to the low altitude at my location but even if you didn't know about the rings Saturn would definitively look very odd compared to other planet (the rings where very noticeable with x15 at the current distance of 8,9AU/1,33 billion km).
glappkaeft is right, Chronos. "Magnification" is a measure of the linear increase in size, not the area increase in size. If you bring an object half as far away, you increase its apparent diameter by a factor of two.
http://www.rocketmime.com/astronomy/Telescope/Magnification.html
How about this, for resolving the actual gap with the naked eye:
The rings start about 7000 km above the visual atmosphere. To resolve this separation with an eyeball that has resolving power of 1' (=60"), the angular separation can't exceed 60":
angular separation (arcseconds) = 206265 Separation/Distance
So,
60 = 206265 * 7000 /D
or
D = 206265 * 7000 / 60 ~ 24 million km (~0.16 AU)
Agreed. Saturn, at 280,000,000 miles would have 25x more area, not 25x more angular diameter. Too much lawnmower exhaust :redface:
  • · Replies 16 ·
  • · Replies 51 ·
  • · Replies 28 ·
  • · Replies 22 ·
