Scaling of a Circle or a Straight Line Using Complex Numbers
The discussion revolves around a problem in complex variables concerning the scaling of geometric shapes, specifically circles and straight lines, through multiplication by a fixed nonzero complex number. The original poster is exploring how this transformation affects the shapes of these loci in the complex plane.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to justify the invariance of the shape of a circle or straight line under multiplication by a complex number, exploring both geometric interpretations and algebraic manipulations. They question whether their reasoning is valid and seek confirmation on their understanding of the effects of the complex number on the shapes.
Some participants have provided feedback on the original poster's reasoning, suggesting that while their approach is on the right track, it lacks rigor. They have encouraged further manipulation of the equations to achieve the desired forms. The original poster has made progress in understanding the case of circles and is now seeking to confirm their reasoning for straight lines.
The original poster is working under a deadline for an assignment and is navigating the complexities of the problem without complete certainty in their interpretations. They express confusion regarding the implications of the real and imaginary parts of the complex number in relation to the transformations of the shapes.
Tsunoyukami
I'm working on an assignment that is due in roughly two weeks and I'm stuck on a problem. I have what I believe may be a solution but am unsure whether or not it is 'complete'. Here is the problem:
"Let C be a circle or a straight line. Show that the same is true of the locus of points [itex]\alpha[/itex]z, z[itex]\in[/itex] C, and [itex]\alpha[/itex] a fixed nonzero complex number." (Complex Variables 2nd Ed. by Stephen D. Fisher; pg. 22, #34)
By multiplying each element contained in the set C by [itex]\alpha[/itex] (ie. essentially a "constant") we are scaling the set. (is this the correct interpretation of what occurs?)
Take, for example, C to be a circle. If [itex]\alpha = 1[/itex] we have the circle C of radius R. If [itex]\alpha > 1[/itex] we have a circle with radius R' > R and if [itex]\alpha < 1[/itex] we have a circle of radius [itex]R' < R[/itex]. That is, by multiplying each each of C by a constant complex number [itex]\alpha[/itex] that 'shape' of the set is unchanged.
The same is true if C is a straight line: the value [itex]\alpha[/itex] instead results in a change in the slope of the original line C when [itex]\alpha = 1[/itex].
Everything above comes simply from me considering the effect of [itex]\alpha[/itex] geometrically in my head without any real 'evidence' involved.
I have tried to justify that the shape of C is unchanged by showing that the form of the set C is entirely equivalent when z is replaced by [itex]\alpha z[/itex]. That is, given a circle of radius R:
C[itex]_{R}(z_{o}) = \left| z - z_{o}\right| = R[/itex]
When z is replaced by [itex]\alpha z[/itex] we can show that the product of two complex numbers [itex]\alpha z[/itex], is itself a complex number. If we let [itex]\alpha z[/itex] = w we find:
C[itex]_{R}(z_{o}) = \left| \alpha z - z_{o}\right| = \left| w - z_{o}\right| = R[/itex]
This has exactly the same form of a circle and so the shape is retained. The same argument can be made for a straight line.
Is this a valid way to show that the shape of the set C is unchanged?
If not, I was considering another process. Again, for a circle, if we multiply all z by the constant complex number [itex]\alpha[/itex] we would expect the radius to scale by a factor [itex]\alpha[/itex] (to see this imagine a circle of radius 1 centered at the origin and choose [itex]\alpha = 2[/itex]. The result is a circle of radius 2 centered at the origin.) In this case we could write the following:
C[itex]_{R}(z_{o}) = \left| \alpha z - z_{o}\right| = \alpha R[/itex]
And transform the equation into the equation of a circle:
I thought this would be more 'proper' but keep getting stuck. Is my first approach valid or should I follow the second - or am I missing something entirely?
Lastly, am I getting the question conceptually? The real part of [itex]\alpha[/itex] is a scaling factor and the imaginary part is a rotational factor - is this correct? I feel a bit more confused for the case of C as a straight line, but I'll work on that once I understand it for the circle.
Any help is greatly appreciated. :) Let me know if anything I have done is unclear and I'll try to clarify it!
Your approach works, but it is not completely rigorous. What you would like is to get the formula after the substitution ##z \to \alpha z## back to the form ##|z - z_0'| = R'## back, where z0' and R' are (different) complex numbers.
To do this, you may want to use that ##|\alpha w| = |\alpha| |w|## for complex numbers ##\alpha, w##. Fiddle with the algebra a bit, and you will be able to define z0' in terms of z0 and α; and R' in terms of R and α.
Thanks a lot, CompuChip! I managed to manipulate it into the form you described above. Is the proof for a straight line similar? A straight line is of the form:
[itex]0 = Re(az + b)[/itex], where [itex]a = A + iB[/itex] and b is a complex number is the straight line [itex]0 = Ax - By + Re(b)[/itex]
Should I be replacing [itex]0 = Re(az + b)[/itex] with [itex]0 = Re(a \alpha z + b)[/itex] and trying to manipulate it into the form [itex]0 = Re(az' + b)[/itex]?
I apologize for double-posting, but I returned to edit my post and found that option unavailable.
I have managed to complete the question for the case of a circle but would like to check my solution for the case of a straight line. As I described above, a straight line can be described by complex numbers by writing:
[itex]0 = Re(az +b)[/itex], where [itex]a = A + iB[/itex] and b [itex]\in[/itex] ℂ. This describes the line [itex]0 = Ax - By + Re(b)[/itex].
By replacing all instance of [itex]z[/itex] with [itex]\alpha z[/itex] we must manipulate the equation [itex]0 = Re(a\alpha z + b)[/itex] into the form [itex]0 = Re(a'z + b')[/itex]. Without any mathematical effort I predict [itex]a' = a\alpha, b' = b[/itex].
[itex]0 = Re((A+iB)\alpha z + b)[/itex]
[itex]0 = Re((A\alpha +iB\alpha)z + b)[/itex]
[itex]0 = Re((A' +iB')z + b)[/itex]
Here we see that [itex]a' = A' + iB' = A\alpha + iB\alpha = (A+iB)\alpha = a\alpha, b' = b[/itex] as I predicted above. Is this a sufficient proof of the claim that if S is straight line then the locus of points [itex]\alpha z[/itex] is also a straight line for any [itex]z \in S[/itex]?
  • · Replies 22 ·
  • · Replies 30 ·
