Does the mass of a blackhole remain the same if it is not feeding ?
  • Context: Graduate
  • Thread starter Thread starter abbott287
    Blackhole Mass
The discussion revolves around the mass of a black hole and whether it remains constant when not actively "feeding" on surrounding matter. Participants explore concepts related to the nature of black holes, the implications of mass and volume, and the effects of gravitational forces during collapse.
  • Some participants question whether the mass of a black hole remains the same if it is not "feeding," suggesting that while the mass may stay constant, the volume decreases.
  • Others mention that the mathematics indicates the mass shrinks down to a point, although it is unclear what prevents further shrinking.
  • Hawking radiation is introduced as a theoretical process by which a black hole might lose mass over an extended period.
  • There is a discussion about the gravitational pull of a black hole formed from a collapsing star, with some arguing it remains the same as the star's pre-collapse gravitational pull.
  • Participants explore the implications of gravitational forces as mass is compacted, referencing the inverse square law and how it affects gravitational acceleration.
  • Some express uncertainty about the effects of compression on gravitational forces at distances greater than the radius of the object, particularly in relation to the Moon's orbit around Earth.
Participants do not reach a consensus on the nature of mass and volume in black holes, with multiple competing views and unresolved questions regarding the implications of gravitational forces and the behavior of matter within black holes.
There are limitations in the discussion regarding the assumptions made about the nature of black holes, the role of quantum mechanics, and the incomplete understanding of gravitational effects at extreme densities.
abbott287
Does the mass of a black hole remain the same if it is not "feeding"?
If matter in a black hole keeps crushing down in size to infinity, does the mass stay the same, but the volume decreases? Isn't a black hole constantly shrinking in size? Thanks in advance for the help!
Astronomy news on Phys.org
We don't actually know WHAT is going on inside a black hole but the math says that the mass shrinks down to a point (but, yes, stays the same amount)
You're thinking of Hawking radiation, which theoretically yes, over a great amount of time, a black hole will radiate off a small portion of it's mass. (Google heat death).
But in the case of our sun, if it were big enough to form into a black hole at collapse, would still have about the same gravitational pull as the sun pre-collapse. You might want to stay away from it in your spaceship though, the event horizon might just swallow you before you find it.
:eek: I actually got one right! :smile:
If it shrinks down to a point, what stops it shrinking from there?
Thats one aspect we don't know. QM feels the minimal size or state is the Planck length. Or could be infitismally tiny. Opinions vary on that
Once the Pauli exclusion limit is exceeded, theoretically there is nothing to prevent the physical volume of mass in a black hole from shrinking to an infinitesimal point called a singularity. This is widely viewed as the mathematical consequence of an incomplete theory. A proper theory of quantum gravity should resolve this paradox.
If that's true, why can light escape from stars with enough mass to form a black hole before they collapse? (If the gravitational pull remains the same, and light can't escape post collapse)
As always, thanks in advance for any help!
Imagine if the Earth were the same mass, but 3,000 km in radius instead of the 6,000 km that it is now. The matter on the far side of the Earth from you is now half the distance that it used to be, which means that the attractive force of gravity from that matter is four times as great due to the inverse square law. If we re-calculate the gravitational force on the Earth we would find that instead of accelerating at 9.8 m/s2 we are now accelerated at about 40 m/s2. If we keep compacting the Earth into a smaller and smaller volume, the force of gravity continues to increase as the average distance between the matter decreases. Eventually we would reach the point where the Earth is so compact that an event horizon forms.
Note, however, that at distance much greater than the radius of the Earth the gravity barely changes. For example, the Moon orbits the Earth at a distance of about 380,000 km. Since that distance is much greater than the radius of the Earth, the gravitational force remains almost exactly the same before and after we compress the planet. This makes sense when you consider that even though parts of the Earth moved towards the Moon during compression, other parts moved away from it.
Drakkith, I always thought the gravity at the moon didn't change at all if the Earth shrinks. Why do you say it is "almost" exactly the same? Is it because our simplification of taking the Earth as a point object becomes more valid as it shrinks in size and that makes a small difference at the moon?
Uh, yes. Let's go with that. :-p
Great explanation! Thank you!
  • · Replies 17 ·
  • · Replies 30 ·
