How Does Weight Impact Momentum and Kinetic Energy in Air Track Experiments?
The discussion revolves around an experiment involving momentum and kinetic energy using an air track with two carts. The original poster describes a setup where one cart is stationary with varying weights added, while another cart is launched at a constant velocity to collide with it. The focus is on understanding the relationship between weight, momentum, and kinetic energy in this context.
  • Participants discuss the potential use of different timing methods for measuring the carts' movements, including spark systems and ticker timers. There is also a question raised about the implications of low friction on the distance traveled by the carts and the effects of varying weights on their motion.
The discussion is ongoing, with participants exploring various aspects of the experiment. Suggestions for improving measurement accuracy have been provided, and there is an active inquiry into the implications of mass differences between the carts. No consensus has been reached regarding the original hypothesis or the specific outcomes of the experiment.
Participants are considering the effects of low friction on the experiment's results and the need for precise timing methods. The original poster expresses uncertainty about the equations and calculations necessary for the experiment.
physicsguru97
Hello I've been doing this experiment which is about momentum and kinetic energy. I'm using an air track and using two carts one 3/4 of the way down with 50g weights I will add to it each time I test it this will be the variable i will be changing the cart will stay stationary. I will launch another cart with a constant velocity each time and it will hit the cart. My hypothesis is that when you increase the weight of the stationary object the distance of the cart moving will be further than the stationary cart. I also have to use all laws i could get out of this experiment
i think i can talk about the conservation of momentum and energy i am really unsure what else i can talk about and i have to show working out using formulas
I believe i can calculate the acceleration using a stop watch but could anyone else suggest any more equations and how to work it out I am quite unsure
Air tracks sometimes have a spark system so they leave marks on a paper tape every 1/25th of a second.
If yours has provision for this, you can do accurate tests.
Others have "ticker timers" which drag a paper strip through a stamping device which also leaves a mark. These are not as good as spark timers, but better than stop watches.
So it would be worth checking if any better timing is available.
I'm not sure about "distance" when the carts are moving on a low friction level track. :confused:
If you have editing software you maybe could use the frame rate of your webcam to determine the speeds of the carts. Regular cm marks are visible on the tracks?
If the two carts have equal mass, the stationary cart will move away from the point of contact, while the moving cart will stop.
If the moving cart is lighter than the other, it will reverse direction and go back the way it came, but slower. The stationary cart will move in the opposite direction.
You can probably guess what will happen if the moving cart is the more massive.
  • · Replies 53 ·
  • · Replies 17 ·
