Timelike Killing vector field and stationary spacetime
The discussion revolves around the definition of stationary spacetimes in the context of general relativity, specifically focusing on the requirement that the Killing vector field must be timelike. Participants explore the implications of this definition, the nature of coordinate systems, and the physical meaning of time in various contexts.
  • Some participants question why a timelike Killing vector field is necessary for defining stationary spacetimes, suggesting that it may be a more general statement than simply requiring the existence of a specific Killing vector.
  • Others argue that the definition of a Killing vector field is coordinate-independent and must satisfy Killing's equation, regardless of the coordinate chart used.
  • There is a contention regarding the assertion that a timelike vector can have non-zero spatial components, with some participants asserting that this is not generally true across all spacetimes.
  • Participants discuss the implications of coordinate transformations and the meaning of "time" in arbitrary coordinate systems, with some emphasizing that "time" may lack physical meaning outside specific contexts.
  • Some contributions highlight that a coordinate system can be constructed such that it represents spacetime as foliated by a family of spacelike hypersurfaces, allowing for a physical interpretation of time in that context.
  • There is a discussion about the interpretation of coordinates and the distinction between "time" and "timelike" coordinates, with some participants noting that labeling a coordinate as time does not inherently confer physical meaning.
  • One participant references a textbook definition of stationary spacetimes, prompting a discussion about the rigor of definitions in academic sources.
Participants express differing views on the necessity and implications of the timelike Killing vector field requirement. There is no consensus on the interpretation of time in arbitrary coordinate systems, nor on the general applicability of certain claims regarding Killing vectors across different spacetimes.
Limitations in the discussion include the dependence on specific coordinate systems, the potential for varying interpretations of "time" and "timelike" across different contexts, and the unresolved nature of certain mathematical steps related to the definitions being discussed.
maxverywell
I am trying to understand why in the definition of a stationary spacetime the Killing vector field has to be timelike.
It is required that the metric is time independent, i.e. the time translations [itex]x^0 \to x^0 + \epsilon[/itex] leave the metric unchanged. So the Killing vector is [itex]\xi^{\mu}=\delta_{0}^{\mu}[/itex]. In other words it is required that there exists a Killing vector that has only [itex]x^{0}[/itex] component and no space components (they are 0). But in general, a timlike vector can also have non zero space components. For example, the vector [itex](1,1/2)[/itex] in two dimensional Minkowski space, is timelike because [itex](1,1/\sqrt{2})^2=-1/2<0[/itex]. This vector is a linear combination of the two independent killing vectors (1,0) (time translations) and (0,1) (space translations) of the 2-d Minkowski spacetime, so it's also a killing vector and it generates translations in time and also in space.
So, if there exists a timelike killing vector with non zero space components, then necessarily there exists the killing vector [itex]\delta_{0}^{\mu}[/itex]. So saying that there should exist timelike Killing vector is because of this? It is simply a more general statement than saying that "spacetime is stationary if it admits the Killing vector field [itex]\delta_{\mu}^{0}[/itex]"?
Um, because that's how the term "stationary spacetime" is defined?
No, that's not true in general. It's only true if you adopt an appropriate coordinate chart. The correct definition of a KVF is that it satisfies Killing's equation:
[tex]\nabla_{\mu} \xi_{\nu} + \nabla_{\nu} \xi_{\mu} = 0[/tex]
This will be true, if it's true, regardless of the coordinate chart you adopt.
This is also not correct in general; it happens to be true in Minkowski spacetime for the particular KVFs you picked, but it's not true in a lot of other spacetimes, or even for other KVFs in Minkowski spacetime.
Thnx Peter! Indeed, the given definition is coordinate independent.
By a coordinate transformation a general timelike vector (with non zero space components) can be transformed to the vector (1,0,0,0), and in this coordinate system, if the metric is independent of the time coordinate, then the vector (1,0,0,0) is a killing vector of this spacetime. But in an arbitrary coordinate system, the metric of stationary a spacetime may depend on time.
You should realize that in an arbitrary coordinate system, "time" has no meaning. You should also realize that by a coordinate transformation, you are taking ##\xi^{a}## to ##\xi^{a} = (\frac{\partial }{\partial t})^{a}##. This is the vector, ##\delta^{\mu}_{t}## is just the coordinate representation - there's a difference.
As WannabeNewton points out, "time" in an arbitrary coordinate system doesn't have any direct physical meaning. (In fact, it's possible to have a coordinate chart without any of the coordinates even being timelike.) That's one good reason why coordinate-independent definitions are preferred.
What do you mean that time has no meaning? When I say time coordinate and space coordinates, I mean ##x^0## and ##x^i## respectively. Should I write timelike coordinate instead of time coordinate? Is there any difference?
On the second I agree, the (1,0,0,0) is the representation of the vector ##\partial/\partial t## in that specific coordinate system, so I should have wrote what you say.
When does it have a physical meaning?
If your coordinate system is constructed in such a way that it represents space-time being foliated by a one-parameter family of space-like hypersurfaces ##\Sigma_{t}##, with ##t## being the time-like coordinate of the coordinate system and the vector field ##\nabla^{a}t## being hypersurface orthogonal to ##\Sigma_{t}##, you can interpret the space-like hypersurfaces as "snapshots" of the space-time at different "times" ##t = \text{const.}## and interpret ##\nabla^{a}t ## as the "flow of time".
"A spacetime is stationary when all the metric components are time independent in some special coordinate system, ##\partial g_{ab}/\partial x^0=0## "
In this special coordinate system the ## x^0## coordinate is the ordinary time t which has meaning :) ? It says time independent...
A space-time is stationary if there exists a one-parameter group of isometries whose orbits are time-like curves. This one parameter family of isometries generates a vector field whose flows lie transport the metric tensor. We interpret this as "time-translation invariance" on account of the orbits being time-like curves. This is as much physical meaning as you can give to the word "time" in a general context with regards to the above.
Are you quoting from something? If so, please give a link to the source. I strongly suspect it's not a very rigorous source.
It depends on the spacetime and on what particular objects in that spacetime are of interest to you.
For example, in some cases, you can find a coordinate chart such that objects of interest to you have constant values for 3 out of 4 coordinates in that chart. If the 4th coordinate is timelike, then that coordinate will often have a direct physical interpretation as the proper time of the objects of interest. But there's no guarantee that you can always find such a chart.
It's from Ray D'Inverno's "Introducing Einstein's Relativity", chapter 14.1 Stationary solutions.
Then he says that ##x^0## is timelike. Is this different from time t? What does it mean that a coordinate is timelike?
In what chart? As I said, there are charts for which there is not even a timelike coordinate at all, including the one labeled ##x^0##. Just labeling a coordinate as ##x^0## doesn't make it a time coordinate, or a timelike coordinate.
(As far as "time" vs. "timelike" is concerned, I don't think there's much difference between them, but that's more a matter of terminology than physics. I tend to prefer "timelike" because it has an obvious mathematical definition: a coordinate ##x^{\mu}## is timelike if its corresponding partial derivative ##\partial_{\mu}## defines a timelike vector field. People use "time" to mean all sorts of things, so that term seems less clear to me.)
(Note, btw, that the definition of "timelike" I just gave makes it coordinate-dependent; the same coordinate can be timelike in one chart and not in another, because the partial derivatives are taken holding the other coordinates constant, and how that is done depends on the chart.)
Ah, ok. I can't exactly say that's a non-rigorous source :wink:, but it is (unfortunately, IMO) true that a lot of textbooks are not as rigorous as they could be about definitions. Here's how I would rephrase the definition:
"A spacetime is stationary if it possesses a timelike Killing vector field, which is a vector field ##\xi^{\mu}## that satisfies Killing's equation. It can be shown that, if there exists such a vector field, one can always find a coordinate chart such that the following is true: (i) there is one coordinate, which we can without loss of generality label ##x^0##, such that ##\partial / \partial x^0## is the coordinate representation of ##\xi^{\mu}##--i.e., the components of ##\xi^{\mu}## in this chart are ##(1, 0, 0, 0)##; and (ii) all of the metric coefficients are independent of ##x^0##."
This should make the logical progression clearer.
Coordinate systems do not necessarily have to be related in any way to one setup by an observer in his/her frame. What you are thinking of is more along the lines of a special tetrad ##(e_{\alpha})^{a}## of basis vectors transported along the worldline of an observer in space-time. In this frame, the observer uses the proper time along his/her worldline to define the "time" coordinate so that ##(e_0)^{a} = u^{a}## where ##u^{a}## is his/her 4-velocity. This lends itself to a more operational interpretation of the "time" coordinate. This tertrad is used, for example, in Fermi-Walker transport.
Actually later he defines a stationary spacetime more rigorously as you did, so the book is ok :)
I think I understand it now (at least much better than before). Thank you very much for your help, both of you!
Yeah the word time-like has precise meaning. I feel like the word "time" is thrown around so much in such a non-chalant way even though it doesn't always have the meaning one would think in the everyday connotation of the word.
No problem, and keep asking the questions like you have thus far. It is really nice! I would strongly recommend the book "General Relativity" - Wald if you want to see more mathematically rigorous definitions of everything in GR as you seem to like seeing. Most of the definitions Peter and I gave in this and other threads of yours (like the spherically symmetric space-times one) come from Wald.
By the way, I have D'Inverno as well and I would say while it is a good book, it is not quite as modern as Wald (although Wald is itself outdated in a sense).
Thanx. I will also check the Wald's book, but I have heard that it's quite difficult. I currently read Sean Carroll's intro to GR, but he doesn't explain some things well, though it is a very good introductory book.
As far as physics goes, I would say there are GR books out there that are much harder (like MTW for example). People may find Wald mathematically difficult but if you've seen the mathematics already then it won't be an issue.
  • · Replies 23 ·
  • · Replies 19 ·
  • · Replies 32 ·
  • · Replies 38 ·
