How Does Moving a Wire Affect Its Mass in a Density Field?
The discussion centers on the relationship between the position of a wire in a density field and its mass, particularly focusing on how moving the wire affects its mass as calculated through a line integral of a density function f(x,y). The scope includes mathematical reasoning and conceptual clarification regarding density and mass in a defined field.
  • Exploratory, Technical explanation, Conceptual clarification, Debate/contested
  • One participant suggests that moving a wire in a density field should change its mass, questioning the relationship between the wire's position and its calculated mass.
  • Another participant clarifies that the density function f(x,y) provides density values for all points in the x-y plane, implying that the mass of the wire is dependent on the specific density values along the curve C.
  • A different viewpoint emphasizes that the weight of the wire is not inherently linked to its position, arguing that a coordinate transformation can maintain the integral's value regardless of the wire's location.
  • One participant challenges the notion that the mass of the wire is predetermined, asserting that the mass depends on the density function and the specific path taken in the line integral.
Participants express differing views on whether moving the wire affects its mass, with some arguing that it does change due to the density function, while others maintain that the mass remains constant regardless of position. The discussion remains unresolved.
Participants highlight the dependence of mass on the density function f(x,y) and the specific path C taken in the line integral, indicating that assumptions about density uniformity or constancy may not hold in all cases.
This discussion may be of interest to those studying physics or mathematics, particularly in topics related to density fields, line integrals, and the implications of coordinate transformations in mass calculations.
mrcleanhands
Wasn't sure which section to put this q in.
Just reading now that f(x,y) can represent the density of a semicircular wire and so if you take a line integral of some curve C and f(x,y) you can find the mass of the wire... makes sense.
What I don't get is that if I then move the wire around the xy axis it's mass will change. What am I missing?
f(x,y) gives you a value of density for all points in the x-y plane. Taking a line integral through that plane is like 'cutting out' a wire from that density plane.
Unless f(x,y) is constant, there is no reason to assume that one wire cut out would be the same density as another.
I think what you're not realizing is that the weight isn't linked to C.
How is weight not linked to C? to find weight/mass you must take a line integral through that plane, and that line integral is C.
What I was confused about is if I take a 3cm wire and position it from (0,0) to (0,3) and then I move it to some other place in the xy plane suddenly it's weight should change right? which is what doesn't make sense to me...
Why would it change? If you move it over then you can simply make a coordinate transformation that brings it back to the original coordinates while leaving the integral unchanged. The coordinate system is simply a computational tool, it won't change the physical amount of mass in the ring.
Because when you take a line integral from (0,0) to (0,3) in a density field z = f(x,y) you're not just finding out what the mass of a 3 cm wire is you're finding out what the mass of a 3 cm wire is when density is defined by z = f(x,y).
In your mind you're thinking that the 3 cm wire already has a predefined mass, and that we use the line integral to find it. Based off of that, you would think that if you moved this wire to another place in the plane that the line integral should evaluate the same because the weight of the wire isn't changing.
But weight is not predetermined without f(x,y) and C. The question is not "what does a 3 cm wire weigh...lets use a line integral to find out", it is "what does a 3 cm wire weigh when every point has density based off of f(x,y)". In the latter case, if the values of f(x,y) change then of course the weight added up with change.
  • · Replies 24 ·
  • · Replies 33 ·
  • · Replies 27 ·
