How Does Absolute Pressure Differ from Gauge Pressure?
The discussion revolves around the differences between absolute pressure and gauge pressure, exploring the underlying mechanisms of pressure measurement and the implications of changing volume in a closed system. It includes theoretical considerations and practical applications related to pressure gauges and their readings.
  • One participant states that absolute pressure is the sum of gauge pressure and atmospheric pressure, questioning how the gauge reads when the volume is halved.
  • Another participant explains that pressure gauges measure differential pressure, typically using a membrane that compares atmospheric pressure to the pressure being measured.
  • A participant introduces additional equipment (graduated cylinder, piston, manometer, temperature sensor) and expresses confusion about the gauge reading when air is pumped in, suggesting that the absolute pressure should be 2 atm while the gauge reads 1 atm.
  • One contributor suggests that the internal pressure will change when the volume is altered, indicating that calibration may be necessary to account for this change.
  • A later post attempts to clarify the formula for absolute and gauge pressure, but the participant still expresses confusion regarding the constancy of atmospheric pressure in the context of their experiment.
Participants express varying levels of understanding regarding the relationship between absolute and gauge pressure, with some agreeing on the basic principles while others remain uncertain about specific applications and implications. The discussion does not reach a consensus on the interpretation of the formula or the behavior of pressure in the described system.
There are unresolved questions regarding the constancy of atmospheric pressure in the context of the experiment, as well as assumptions about the calibration of pressure gauges and the effects of volume changes on internal pressure.
sgstudent
The formula for absolute pressure is absolute P=gauge P+atmospheric pressure. So when the gauge is at 0 it's actually 1 atm. So using the gas law if I were to half the volume the pressure would increase to 2 atm. So would the gauge read 1 atm when this happens?
So how does the mechanism allow it to read the absolute pressure minus the atmospheric pressure only?
You understanding of the math is correct.
The thing to get about how pressure gauges work is that all of them measure differential pressure between two points.
They tend to just be a membrane or similar apparatus that has the atmosphere on one side and what you are measuring on the other.
Hi thanks for the reply :)
Actually its not just a pressure gauge. There's a graduated cylinder with a piston, manometer and temperature sensor. So I thought when we pump in air from the outside the pressure inside would be 1 atm but the gauge would read 0. So now when we half the volume, the pressure doubles. So the absolute pressure should be 2 atm. So using the formula absolute P=gauge P+1atm. Gauge pressure should be 1atm.
However I don't really get why the 1 atm remains constant here. Aren't we just manipulating the 1 atm we already had in there? So I don't get the formula in this sense.
Whatever system is used, it's based on the difference between two pressures. I think your concern is about comparing an external pressure with a reference pressure (inside some reservoir). I think it has to be true that altering the (finite) volume of the inside reservoir will change its pressure (i.e. the internal pressure will no longer be 1atm) but that effect can be eliminated by calibrating the scale on the device.
P(abs) = P(atm) + P(gauge) IF P(abs) > P(atm)
P(abs) = P(atm) - P(gause) IF P(abs) < P(amt)
I hope this helps ;)
  • · Replies 67 ·
  • · Replies 32 ·
14K
  • · Replies 69 ·
  • · Replies 18 ·
