Thomas Precession, Angular Momentum, and Rotating Reference Frames
The discussion revolves around the Thomas precession, angular momentum, and the behavior of physical vectors in rotating versus non-rotating reference frames, as described in John David Jackson's Classical Electrodynamics. Participants explore the implications of the equations governing these concepts, particularly in the context of circular motion and relativistic effects.
  • One participant presents an equation relating physical vectors in rotating and non-rotating frames, leading to a contradiction when applying it to circular motion.
  • Another participant suggests the possibility of missing gamma factors in the acceleration equation, questioning the calculations made by the original poster.
  • A different participant asserts that both acceleration and velocity are measured in the lab frame, implying no Lorentz transformations should apply.
  • Another participant emphasizes that velocity, angular velocity, and position are mutually orthogonal in the context of circular motion.
  • A participant clarifies that the Thomas precession is a relativistic effect that adds to the usual rotation, which may not be clear to all participants.
  • One participant expresses confusion regarding the interpretation of the velocity in the lab frame, questioning whether it aligns with the non-rotating frame's measurements.
Participants exhibit disagreement regarding the interpretation of the equations and the implications of the Thomas precession, with no consensus reached on the source of the contradiction or the correct interpretation of the velocity in different frames.
Participants note potential limitations in their understanding of the relativistic effects and the conditions under which the equations apply, particularly in the context of circular motion and the definitions of the involved variables.
Izzhov
If any of you have the Third Edition of Classical Electrodynamics by John David Jackson, turn to section 11.8, as that's where I'm getting all this from. If not, you should still be able to follow along.
In said section, Jackson gives us this equation that relates any physical vector G in a rotating vs. non-rotating reference frame:
[itex]\left(\frac{d\mathbf{G}}{dt}\right)_{nonrot} = \left(\frac{d\mathbf{G}}{dt}\right)_{rest frame} + \boldsymbol{\omega}_T \times \mathbf{G}[/itex]
where
[itex]\boldsymbol{\omega}_T = \frac{\gamma^2}{\gamma+1}\frac{\mathbf{a}\times\mathbf{v}}{c^2}[/itex]
"where a is the acceleration in the laboratory frame," according to the textbook. Also, gamma is defined using v, the velocity of the particle in the lab frame.
Ok. So I decided to check this by setting G = x, the position vector, for a particle that is undergoing circular motion in the laboratory frame. So we have
[itex]\left(\frac{d\mathbf{x}}{dt}\right)_{nonrot} = \mathbf{v}[/itex]
and
[itex]\left(\frac{d\mathbf{x}}{dt}\right)_{rest frame} = 0[/itex] because the particle doesn't have any velocity in its own frame.
So far so good. Now, this implies that [itex]\boldsymbol{\omega}_T \times \mathbf{x} = \mathbf{v}[/itex]. So if we can get this result from the definition of [itex]\boldsymbol{\omega}_T[/itex], we're golden. However, if you use the fact that [itex]|a| = \frac{v^2}{|x|}[/itex] for circular motion as well as the fact that a is perpendicular to v, and that a is parallel (really antiparallel) to x, and carefully apply the right hand rule, you'll find, after the algebraic dust settles, that
[itex]\boldsymbol{\omega}_T \times \mathbf{G} = (1-\gamma)\mathbf{v}[/itex]
So this is definitely a contradiction. Because it implies that [itex]\mathbf{v} = (1-\gamma)\mathbf{v}[/itex]. Can anyone tell me where this went horribly horribly wrong? I worked on this with my professor for two hours today and we couldn't figure it out.
Could it be that you dropped some ##\gamma## factors in ##|a| = \frac{v^2}{|x|}## ?
I don't believe I did, because if the book is to be believed both a and v are being measured in the lab frame, which would mean there's no Lorentz transformations going on there.
and
Wasn't v supposed to be the velocity in the lab frame?
V is a relative velocity, it doesn't matter what frame it's measured in.
Another point is that ##\omega##,##v## and ##x## are mutually orthogonal if the origin is the centre of rotation. ##v## and ##x## are in the plane of rotation and ##\omega## points away from it.
Izzhov, You misunderstand the meaning of the Thomas precession. It is not simply the usual difference between a rotating frame vs the lab frame. It is a relativistic effect ON TOP OF the usual rotation. In the nonrelativistic limit it goes to zero. Hence the (γ -1) factor.
Now I'm confused. Are you telling me that [itex]\left(\frac{d\mathbf{x}}{dt}\right)_{nonrot}[/itex] is not, in fact, the velocity as measured in the lab frame? If not, what is it?
  • · Replies 0 ·
  • · Replies 38 ·
  • · Replies 47 ·
  • · Replies 23 ·
  • · Replies 20 ·
