Why 2 photons are formed from positron-electron annihilation at rest
The discussion centers on the phenomenon of positron-electron annihilation at rest and the resulting formation of photons. Participants explore why this process predominantly results in the emission of two photons rather than a larger number, while also considering related concepts such as positronium and the mechanics of particle interactions.
  • One participant notes that while a single photon cannot be produced due to momentum conservation, the dominance of two-photon annihilation is attributed to its simplicity in terms of interaction points in Feynman diagrams.
  • Another participant mentions that any number of photons can theoretically be produced except one, with two photons being the most common outcome due to the nature of the interaction.
  • There is a discussion about positronium, where one participant expresses confusion over its role in annihilation, suggesting that it must form before annihilation occurs.
  • Another participant clarifies that while positronium can decay into two or three photons, a positron-electron pair does not necessarily need to form positronium to annihilate.
  • One participant references theoretical ratios of photon emissions in annihilation events, indicating that higher photon emissions are significantly suppressed compared to the two-photon case.
Participants express differing views on the necessity of positronium formation in annihilation and the implications for photon emission numbers. There is no consensus on the mechanisms involved or the conditions under which different photon numbers may arise.
Some participants mention specific theoretical frameworks and ratios related to photon emissions, but these discussions are not fully resolved and depend on various assumptions about particle interactions.
phosgene
This isn't a homework question, though it kind of relates to a practical I did recently. Sorry if it's posted in the wrong section!
So, why are only 2 photons formed from positron-electron annihilation at rest? I understand why you can't have just one, as then you won't get conservation of momentum. But why do you only get 2 photons instead of say, 10 or 1000? I've looked up various particle physics textbooks and one on radiation detection, but they only explain that you can't get a single photon.
As far as I know, you can get any number of photons except 1, but the reaction to two photons is really dominating, as it just needs [strike]one[/strike] two vertices ("interaction points") (edit: fixed) in the Feynman graph. In addition, the photons always have the same energy, so it is easy to detect.
3-photon annihilation, suppressed by a factor of 370.
Positronium is interesting, as it has one short-living state (which decays to two photons) and one long-living state (which cannot do this, and has to decay to three photons)
Thanks for the reply. I don't quite understand, though. I thought that positron-electron annihilation always occurs when a positron captures an electron to form positronium, which then decays. If positronium can only decay into 2 and 3 photons, doesn't this rule out the decay into other numbers of photons?
Those numbers for positronium are just the most likely numbers (as all lower numbers are forbidden), and a positron/electron pair does not have to form positronium to annihilate.
but the reaction to two photons is really dominating, as it just needs 1 vertex ("interaction point") in the Feynman graph
there are two vertex in annihilation.There is a electron or/and positron internal line between the two photons.
Oops, thanks. I imagined two and wrote one.
Ah, I see. I guess the other mechanism is a plan old collision? The wording of Das and Ferbel's intro to nuclear and particle physics seemed to imply that positronium always formed before an annihilation, so I just assumed that it formed in a collision.
This:
http://arxiv.org/pdf/hep-ph/0310099v1.pdf
gives the theoretic ratios of 4 photon annihilation to 2, and 5 photon annihilation to 3, in the region of 1/1 000 000. Experiments are similar, though they have measurement errors.
14K
  • · Replies 17 ·
  • · Replies 23 ·
