Can I trap a gas in a beer bottle with an ordinary bottle capcap?
  • Thread starter Thread starter algar32
    Beer Gas
The discussion revolves around the feasibility of trapping neon gas in a beer bottle using a standard bottle cap to create a plasma ball effect. Participants explore the practicalities of sealing the bottle and the challenges associated with the design and visibility of the plasma effect.
  • Some participants suggest that trapping neon gas in a beer bottle is possible, but it depends on the type of gas and the effectiveness of the bottle cap seal.
  • Concerns are raised about the need for an electrode inside the bottle and the difficulty of achieving this with a metal cap sealed with rubber.
  • Visibility issues are mentioned, particularly regarding the darkness of the bottle and how it may affect the plasma display.
  • One participant proposes modifying the cap by cutting away some rubber to accommodate the electrode, while another questions the practicality of this approach.
  • Alternative sealing methods are suggested, such as using a different part of the bottle for the seal and hiding the wiring to maintain the appearance of a normal beer bottle.
  • Safety concerns are highlighted, including the risks of glass breaking and high voltage electricity, with a suggestion that there may be safer methods to achieve a similar effect.
  • Humorous suggestions are made about alternative ways to create a "corona" effect, including using a Toyota Corona car as a container.
Participants express a mix of skepticism and curiosity about the project, with no clear consensus on the feasibility or safety of the proposed method. Multiple competing views remain regarding the practicality of sealing the bottle and the effectiveness of the plasma display.
Participants acknowledge limitations related to the sealing methods, visibility of the plasma effect, and safety concerns, but do not resolve these issues.
algar32
Can I trap a gas in a beer bottle with an ordinary bottle capcap??
I would like to trap neon gas in a beer bottle with a bottle capper. My goal is to build a plasma ball (tesla ball) in a beer bottle so I can have corona in my corona :P.
I plan on building the tesla coil into the bottom of the cap, so that I can pop it on and be good to go. I am planning on using a circuit similar to this one built into a light bulb (which already has the gas trapped in it): http://www.rmcybernetics.com/projects/DIY_Devices/homemade_plasma_globe.htm
At this point I really just need to know if there is a practical way of filling the bottle and if a bottle cap will provide a sufficient seal. Thanks.
Chemistry news on Phys.org
Probably - depends on the gas, and the bottle cap.
I would be using a standard beer bottle cap (probably try to recycle a corona cap or just use a new one). I think I hear neon can be used as one of the primary gases in plasma balls. Suppose it was just neon, do you think I would be able to easily accomplish my goals? Thanks.
Two reasons why I don't think it will work.
First, you need to put the electrode inside - and I don't see it being done through a metal cap sealed with a rubbery layer.
Second, bottle is relatively dark, so whatever happens inside will be barely visible outside.
Other than that, if we are talking about pressures similar to those in the light bulb (in the range of 0.7 atm), there should be no problem, as the bottles are designed to stand some pressure from carbon dioxide (although working in the opposite direction).
I am not sure I fully understand your concern with the electrode... I was planning to cut away some of the rubber in the middle of the cap if I had to.
Your second concern about the bottle darkness shouldn't be a problem because I will be using a corona bottle with clear glass (I may be misunderstanding your concern though).
Thanks for your feedback.
Then you will have to seal the cut. Doable, but if you are going to additionally seal it, why bother with using a cap that will no longer look like a cap?
OK. Somehow I always drink beer from dark brown or green bottles. Never thought about it before :smile:
I would try to cheat it by using something else in the neck to actually do the seal and put a normal cap on afterwards.
I'd consider running the wires for the electrodes through another part of the bottle - the base (so you can have your bottle standing upright) or the side (so the bottle will be displayed lying down) ... hide the wires and leads, stain the inside amber too - simulate beer, and it will look like a normal corona bottle ... at first glance, then you switch it on.
This does mean finding a way to drill holes in the glass (hint: carefully - and put tape over the drill spot first) and then sealing them up afterwards.
Put the gas in the bottle via the neck, ram whatever sealant you are using in there than you can cap it normally.
You may want to collect a dozen or so bottle to, you know, practice on, ... the following evening...
I don't think there is anything intrinsically stopping this from working.
OTOH: the instructions on that site sound dicey - take care aye?
And post pics.
Aside: I'm guessing this one was stopped for moderation due to safety concerns?
Yes. And we are still watching the thread.
Safety concerns have been discussed already? Shall we make then explicit for the sake of anyoe who googles here.
I figure - possible glass breaking, and high voltage electricity being the main ones.
The actual discharge being considered is quite small.
There's probably a better/safer way to get a corona in a corona ...
:smile:
... sadly not my joke - was made in post #1.
One could put a bottle of corona beer in a Toyota Corona?
... <crickets>
Somehow - that does not have the same "cool" factor.
Would it be good enough just to fill a corona bottle with neon and make the neon glow by proximity to a commercial plasma globe?
No?
Mind you, I can imagine getting a Toyota Corona body, sealing it (hard work I know), filling it with argon or something and running a couple of high voltage leads... don't look at me like that: it's art I tell you!
Thanks for the advice. I will keep you guys posted. This should be interesting :)
  • · Replies 186 ·
97K
  • · Replies 19 ·
  • · Replies 30 ·
