Spin of electrons within (x,y,z) 2P orbitals
The discussion centers on the quantum behavior of electrons in the 2P orbitals, specifically addressing the implications of spin states (spin-up and spin-down) for lone electrons in these orbitals. Participants explore whether there are quantum constraints on the spin configurations of electrons occupying different 2P orbitals, particularly in the context of carbon's electronic structure.
  • Some participants question whether a lone electron in any of the three 2P orbitals must always be in a spin-up or spin-down state, suggesting that configurations like spin-up in 2Px and spin-down in 2Py could coexist.
  • Others argue that an electron's spin is inherently tied to its alignment with a specific direction, complicating the idea of having different spins in separate orbitals.
  • A participant notes that in carbon (1s22s22p2), the electronic states with parallel spins are distinct from those with opposed spins, with the former being lower in energy.
  • Some contributions highlight that electrons do not need to be in an eigenstate of spin along a particular axis, and the representation of spins as arrows is a simplification.
  • There is a discussion about whether electrons in different orbitals can be considered 'paired' and how spatial separation affects this pairing, with one participant expressing confusion over the definitions of pairing in this context.
  • Another participant introduces the concept of magnetic moments as a way to determine whether electrons are paired, referencing the C-12 isotope's zero magnetic moment as evidence of unpaired electrons in different orbitals.
  • Some participants challenge the interpretation of magnetic moments and pairing, suggesting that the electrons must be paired to yield a zero magnetic moment, while others argue that they can be unpaired across different orbitals.
The discussion remains unresolved, with multiple competing views on the nature of electron spins in different 2P orbitals, the implications of magnetic moments, and the definitions of pairing. Participants express differing opinions on whether the electrons in carbon's 2P orbitals are paired or unpaired based on experimental evidence.
Participants reference Hund's Rule and experimental data regarding magnetic moments, indicating that assumptions about pairing and energy states may depend on specific conditions and interpretations of quantum mechanics.
Salman2
Question. Is there a quantum reason why a lone electron in any of the three available (x,y,z) 2P orbital energy states must always be spin-up or spin-down ?
Every figure I see always shows a single electron as spin-up for the three 2P energy states, but is there a quantum theory constraint that would not allow an electron in 2Px to be spin-up, while simultaneously, another in 2Py would be spin-down ?
Chemistry news on Phys.org
An electron has spin 1/2. If it has spin up (or down) in one direction, its spin is aligned with that direction. It cannot be aligned with two different directions at the same time.
A second electron? I would expect that their spin coupling leads to trouble there, but I don't know.
Taking carbon as an example (1s22s22p2), the electronic state with the 2p spins parallel is a distinct state from the one with the 2p spins opposed. The two states are not energetically equivalent. It turns out that the first state lies at the lowest energy, while the second state corresponds to an excited state of the carbon atom.
The electrons don't have to be in an eigenstate of s_z. The pictures with the spin symbolized by an arrow pointing up or down is an (over-)simplified picture. However if you have two electrons it makes a difference whether the spins are paired into a triplet (parallel arrows) or singlet (anti-parallel arrows). A singlet/triplett will always be a singlet/ triplet independent of the choice of the quantization axis.
Thanks. I have a question. Do we know the first spin parallel state is at lower energy using Hund's Rule, or experiment, and if the latter, do you have a reference ?
Thank you. I have a question. Can we really say the single electrons found in 2px and 2py are 'paired' since they occupy completely different orbitals along the x,y,z coordinates ? Seems to me that the singlet [itex]\uparrow[/itex][itex]\downarrow[/itex]and triplet states [itex]\uparrow[/itex][itex]\uparrow[/itex] or [itex]\downarrow\downarrow[/itex]would only apply when two spins are 'paired' with close packing within any single 2px or 2py or 2pz orbital within the second energy level beyond the core 1s energy level.
Consider the possibility that a single [itex]\uparrow[/itex] e- is located in one lobe of the 2px orbit, and a second [itex]\downarrow[/itex] e- is located in one lobe of the 2pz orbit at angle > 90 degrees opposite. There is no quantum reason such electrons must be in orbits next to each other, such as x-y or y-z, that is, x-z equally possible. So, how do we conclude that these two electrons are 'paired' and can form a singlet state when they are spatially greatly separated, as compared to two electrons within any specific 2p orbit, which clearly are 'paired' due to close packing within a given orbit ? Clearly I am confused.
The situation for two electrons in different orbitals is more involved. If spin orbit coupling can be neglected, singlet and triplet states are different eigenstates of the hamiltonian, i.e. they have different energies. Thus any superposition of singlet and triplet is possible but will change in the course of time.
As p orbitals carry angular momentum, when spin orbit coupling is taken into account, the eigenstates of the hamiltonian will no longer be pure singlets and triplets
Are you perhaps confusing the way that electrons are CALCULATED in open-shell singlet calculations (where up and down spins are allowed to "be" in different spatial orbitals even though their are the same number of up and down spins) with the fact that they are paired or not paired? The first is a model of nature meant to give more accurate total energy differences, the second is an experimentally testable fact (does the system have an overall magnetic moment or not).
Thanks, very useful comment to include magnetic moment to help determine if two unpaired electrons in 2p are paired or not. So, take C-12 isotope for example. It has two single e- within two separate 2p orbitals, 2px [itex]\uparrow[/itex]and 2py[itex]\uparrow[/itex]. It is known experimentally that C-12 has 0.0 magnetic moment. Therefore, we know via experiment (not Hund's rule) that the two e- in 2p energy level ARE NOT PAIRED, since, if they were paired, C-12 would have a magnetic moment > 0.0. Experimental data on magnetic moments takes priority over Hund's Rule to help understand pairing or not of the 2p electrons in C-12 isotope.
Thus, concerning my OP question, given the experiment data on C-12 that it has magnetic moment = 0.0, this means the two single electrons in the 2px and 2py orbits of C-12 could be either [itex]\uparrow[/itex][itex]\uparrow[/itex] OR [itex]\downarrow[/itex][itex]\downarrow[/itex] OR [itex]\uparrow[/itex][itex]\downarrow[/itex], that is, BECAUSE THEY ARE NOT PAIRED, all quantum spin states are equally possible for each individual 2p orbital.
Do I have this all correct ?
I think the above is incorrect.
The 2p electrons in C-12 must be PAIRED to have a magnetic moment = 0.0. See this link for C-12 magnetic moment: http://www.webelements.com/carbon/isotopes.html. Elements with unpaired e- are called paramagnetic, but clearly C-12 is diamagnetic since magnetic moment = 0.0.
Of interest is that two e- of C-12 are not paired within the same x,y,z orbit of 2p, but they are paired in two different 2p orbits. From comments below by Gadong, using NIST table reference, C-12 has the two e- in 2p in triplet state [itex]\uparrow[/itex][itex]\downarrow[/itex] in ground state, and this triplet state, from PAIRED e- found in two different 2p orbits, results in C-12 having a 0.0 magnetic moment.
What is very confusing is that I have read that CARBON as an element is paramagnetic (thus magnetic moment > 0.0) because it has two UNPAIRED electrons in 2p...but this is factually incorrect for the C-12 isotope given that experimental data shows magnetic moment is 0.0.
A Google search for {singlet carbon atom} provided the following reference:
http://www.tcm.phy.cam.ac.uk/~mdt26/downloads/hongo_hund.pdf
Normally I would check the ground states of atoms using the NIST periodic table at http://www.nist.gov/pml/data/periodic.cfm which is a respectable source, and can be used as a reference. The carbon ground state is a triplet. By implication, if a state is not the ground state, it is an excited state.
Thanks, but I am confused. The first reference indicates the ground state for carbon is singlet, but the NIST table has it being triplet...which is correct ?
Also, how does any of this help explain the fact that C-12 isotope has a magnetic moment = 0.0 while C-13 isotope has magnetic moment = 0.7024 ? This would mean C-13 isotope is paramagnetic and thus has the e- in 2p being UNPAIRED, while C-12 isotope is diamagnetic with the two e- in 2p being PAIRED...how the heck does Hund's Rule explain the different experimental magnetic moments for C-12 and C-13 isotopes ?
See this link for C-12 and C-13 magnetic moment: http://www.webelements.com/carbon/isotopes.html
Also this article finds the triplet state as the ground state and the singlet as an excited state.
C-13 contains an extra neutron, which is a spin 1/2 particle.
Edit: OK, I see from comment below by DrDu that both references put triplet state [itex]\uparrow[/itex][itex]\uparrow[/itex] as ground state for C-12 for 2p orbits. Also, I now see that differences in magnetic moment between C-12 and C-13 is due to addition of the neutron in C-13.
Edit: Removed confused comments
Edit: OK, from comment below the difference in magnetic moments between C-12 and C-13 is due to added neutron.
Note to readers of thread. Getting back to my OP question, and all the replies, here are my conclusions, using isotope C-12 for example:
1. The two e- in 2p energy level are in triplet state, symbolically [itex]\uparrow[/itex]in state 2px orbit and [itex]\uparrow[/itex]in 2py
2. Because C-12 has 0.0 magnetic moment, the two [itex]\uparrow[/itex][itex]\uparrow[/itex] are paired, but they are paired in two different 2p orbits, not within the same orbit.
If this is correct we can end the discussion.
1 is right and 2 is not. In 2 you're confusing the nuclear magnetic moment with the number of unpaired electrons. A free neutral carbon atom is a spin triplet and has two electrons of the same (unpaired) spin. That's what a triplet means. A neutral and free Carbon 13 atom is also a spin triplet for the exact same reason.
  • · Replies 0 ·
  • · Replies 74 ·
  • · Replies 21 ·
