Why does pulmonary oedema give pink frothy sputum?
  • Thread starter Thread starter sameeralord
The discussion revolves around the phenomenon of pulmonary oedema and its association with pink frothy sputum. Participants explore the underlying mechanisms of pulmonary oedema, particularly in the context of left heart failure, and question why a condition characterized by transudate fluid in the alveoli would present with symptoms indicative of blood.
  • One participant states that pulmonary oedema typically occurs in left heart failure, leading to increased hydrostatic pressure and fluid accumulation in the alveoli, which is described as a transudate that does not contain blood.
  • Another participant suggests that the presence of blood in the sputum may result from associated tissue damage, which could be a contributing factor to the condition.
  • A third participant expresses confusion regarding the presence of blood, emphasizing that pulmonary oedema is characterized by transudate and questioning the occurrence of capillary damage.
  • A later reply challenges the assumption that no damage occurs, proposing that the presence of blood indicates some form of lung damage, whether from the condition itself or related factors. This participant raises questions about potential causes of lung damage, such as violent coughing or increased pulmonary blood pressure leading to capillary rupture.
Participants exhibit disagreement regarding the relationship between pulmonary oedema and the presence of blood in sputum, with some asserting that damage must occur while others maintain that transudate does not imply capillary damage. The discussion remains unresolved.
Participants have not reached a consensus on the mechanisms leading to the presence of blood in pink frothy sputum associated with pulmonary oedema, and there are varying interpretations of the definitions and implications of transudate versus damage.
sameeralord
Hello everyone,
You usually get pulmonary oedema in conditions such as Left heart failure, where there is increasesd back pressure in pulmonary vasculature, which in turn increase hydrostatic pressure and then fluid in alveoli giving rise to the condition. Now my question is this fluid in alveoli is a transduate it does not contain blood, however the classic symptom of this condition is pink frothy sputum which indicates blood. Why is this the case. Thanks :smile:
Biology news on Phys.org
The blood, where it appears, comes from associated tissue damage.
The damage may even be the cause of the condition.
Thanks for the reply Simon :smile: But pulmonay oedema is an transduate, capillaries don't get damaged. I don't understand.
You are thinking about the problem backwards - you deduce from the definition of the condition that there is no damage and therefore blood cannot appear as a symptom accompanying the condition. What you should be thinking is that blood definitely does appear in connection with the condition, therefore damage must occur - if not by the condition itself than in relation to the condition. How many different ways can a patient damage their lungs?
Do you think that the presence of a pulminary oedema somehow protects capillaries from subsequent damage? Say from violent coughing brought on by having fluid in the airways? Could the increased pulmonory BP also rupture capilliaries? What about those cases where physical trauma to the tissue is the cause of the oedema?
25K
  • · Replies 16 ·
27K
12K
