Electric potential of water droplets
The problem involves calculating the electric potential of a larger water droplet formed by the coalescence of 27 smaller charged droplets, each with a specified diameter and charge. The subject area includes concepts of electrostatics and geometry related to spheres.
  • Mixed
  • Participants discuss the need to determine the total charge and radius of the larger droplet formed from the smaller ones. There are questions about the method of calculating the potential and whether it should be expressed as a function.
Some participants have provided guidance on how to find the radius and total charge of the larger droplet, while others are questioning the calculations and results presented, indicating a lack of consensus on the values derived for radius and potential.
There are discrepancies noted regarding the calculations of the radius and potential, with participants pointing out different interpretations of the problem's parameters, such as the diameter of the smaller droplets.
tsgkl
Twenty seven charged water droplets each with a diameter of 2 mm and a charge of 10-12 C coalesce to form a single drop .Calculate the potential of the bigger drop.
V(potential)=[itex]\frac{q}{4∏εr}[/itex]
i don't really have an idea from where to start...please help...
Calculate the potential where? Or do you need to find it as a function?
Well we know that the 27 drops are forming into a bigger drop. So now you have a big drop who's charge and radius is unknown - you have to calculate the potential of that. Try to find out the radius and total charge of the new big drop.
The volume of bigger drop will be equal to volume of 27 small drops
From here find the radius
and charge is conserved , so add the total charge
radius came out to be 10-3 m and finally potential came out to be 81V...thanks for helping guys...
How? The radius comes out to be 6x10-3m and not 10-3m. And the potential comes out to be 81/2 Volts and not 81 Volts. Can somebody please verify?
27x4/3x∏x(2)3=4/3x∏x(R)3
=> R3=23.33
=> R=6mm=6x10-3m
=>Vbig drop=1/(4∏εo)xQ/R=9x109x27x10-12/6x10-3=81/2V
The problem specifies that the DIAMETER of the small drops is 2mm. The radius of the large drop should turn out to be 3 x 10-3 m , or 3 mm.
  • · Replies 23 ·
