Change in position/t greater than speed of light?
The discussion centers on the impossibility of exceeding the speed of light when considering the relativistic law of velocity composition. Specifically, the formula (u+v)/(1+uv/c²) demonstrates that if an object moves with velocity u and carries another object with velocity v, their combined speed cannot surpass the speed of light, c. The consensus is that regardless of the velocities involved, as long as they are less than or equal to c, the resultant speed remains below c. This conclusion is supported by the contributions of forum member Bill_K.
  • Understanding of special relativity principles
  • Familiarity with the speed of light (c) and its implications
  • Knowledge of relativistic velocity addition formula
  • Basic grasp of physics concepts related to motion and velocity
  • Study the implications of Einstein's theory of special relativity
  • Explore the derivation and applications of the relativistic velocity addition formula
  • Investigate the concept of time dilation and its relation to speed
  • Examine experimental evidence supporting the speed of light as a universal constant
Physics students, educators, and anyone interested in the fundamental principles of relativity and the nature of speed in the universe.
howabout1337
Is it possible to travel further in distance (position 2 - position 1) over a unit time more than that of traveling at the speed of light? This is not wormhole, or anything that sort, just change in position.
I am coming from the fact that a moving particle can exist on a moving object.
Same answer as in your previous thread:
Now, relativity says you must use the formula (u+v)/(1+uv/c2)
If an object is moving with velocity u, and carrying a moving object whose velocity is v, you don't simply add u + v. The relativistic law of velocity composition guarantees that the speed of light cannot be exceeded.
The short answer is "No". Bill_K showed why above. Look at the formula he posted. If u and v are both less than c then the result is always less than c. If either u or v is c then the result is c, regardless of what the other one is.
  • · Replies 26 ·
  • · Replies 42 ·
  • · Replies 51 ·
  • · Replies 21 ·
  • · Replies 45 ·
