Instanteneous velocity question
  • Thread starter Thread starter jhson114
    Velocity
The discussion revolves around the concept of instantaneous velocity in the context of two cars, A and B, traveling in a straight line. The original poster questions whether car A must have a greater instantaneous velocity than car B at the moment they are adjacent, particularly when considering different scenarios of constant and accelerating speeds.
  • Participants explore the relationship between the velocities of the two cars, questioning the implications of constant versus accelerating speeds. They discuss whether car A's ability to pass car B necessitates a greater instantaneous velocity at the moment of passing.
There is an ongoing exploration of the conditions under which car A can pass car B, with some participants affirming that if both cars are traveling at constant speeds, car B cannot overtake car A once passed. Others note the distinction between constant and accelerating speeds and how that affects the concept of instantaneous velocity.
Participants are considering various assumptions about the speeds and accelerations of the cars, including the implications of constant speed versus acceleration on the concept of instantaneous velocity. There is a lack of consensus on how these factors interact in the context of the problem.
jhson114
two cars A and B are traveling in a straight line. Car A is passing car B and at time t1, car A is adjacent to car B. If each cars are traveling in a constant speed ( each with separate constant speed), at time t1, instanteneous velocity of car A should be greater than car B right?? since in order for car A to pass car B, velocity of car A has to be greater than car B, and since their velocity is constant throughout motion, car A should have greater instanteneous velocity at t1.
also, it shouldn't matter if car B is accelerating and car A is traveling in a constant velocity.. right? since even though B is accelerating car A must have greater velocity at t1 in order to pass car B, therefore instanteneous of car A should still be greater. please correct me if I'm wrong. thank you
Correct. Car A can't pass Car B if they both have constant velocities and car B has a higher one.
Car A can't pass Car B unless its velocity at the time of passing is greater, correct. However, there's no say as to what may happen later on:
The position equation for Car A and Car B are as follows:
[tex]x(t)_a = v_0t[/tex]
[tex]x(t)_b = v_{0b} + \frac{at^2}{2}[/tex]
It is very possible that the initial velocity of car B will be lower than Car A, at which point t=t1 car A will pass, but as t increases, the acceleration will eventually cause car B to pass car A again.
If each car is traveling at a constant speed as you say, then neither car is accelerating, which means that once car A passes car B, car B will not overtake car A again.
In fact, if both cars are traveling at constant speed, there is no need to talk about "instantaneous" velocity- instantaneious= average= constant speed will do nicely.
If B is accelerating, then you do need to say "instantaneous". Of course, knowing only the acceleration tells you nothing about the speed at a giving instant.
  • · Replies 25 ·
  • · Replies 30 ·
  • · Replies 33 ·
