How Does Angular Speed Change When Skaters Connect by a Pole?
The problem involves two skaters approaching each other on frictionless ice, connecting by a pole, and the discussion centers on determining their angular speed after connection. The subject area includes concepts of angular momentum and moment of inertia.
  • Participants discuss the use of conservation of angular momentum and the calculation of moments of inertia. Questions arise regarding the correct expression for moment of inertia and the conversion between linear and angular velocities.
The discussion is ongoing, with participants providing insights into the relationships between linear and angular quantities. Some guidance has been offered regarding the formulation of the angular momentum equation, but there is no explicit consensus on the correct approach or solution.
Participants are working under the assumption of negligible mass for the pole and identical parameters for both skaters. There is uncertainty regarding the correct application of formulas and the interpretation of the moment of inertia.
Punchlinegirl
Two skaters, each of mass 85 kg, approach each other along parallel paths separated by 3.5 m. They have equal and opposite velocities of 1.6 m/s. The first skater carries one end of a long pole with negligible mass, and the second skater grabs the other end of it as she passes. Assume frictionless ice. Describe quantitatively the motion of the skaters after they have become connected by the pole. What is their angular speed?
I know that to solve this I need to use conservation of angular momentum, but I'm unsure what the moment of inertia is. Would it just be .5MR^2?
Just add the moments of inertia of the two skaters with respect to the axis of rotation (center of pole). The moment of inertia of one person (treated as a point particle) is mr^2.
Ok, I used:
L init= L final
Iw= Iw
mr^2 = (mr^2 + mr^2) w
I converted the linear velocity to angular velocity, v=wr
subsituting gives
85(3.5^2)(.457)= 2(85)(3.5^2) w
and dividing gives w= .229 rad/s, which isn't right.
Can someone tell me what I did wrong?
Since the parameters for both skaters are the exactly the same both sides of the angular momentum equation will be exactly the same as well if you write them in terms of the same quantities.
I.e. Iw = Iw (2mr^2)w = (2mr^2)w
try using the fact that L = (m+m)vr = 2mvr along with Iw
  • · Replies 20 ·
13K
15K
