What Is the Correct Distance d in the Parallel Axis Theorem for a Cube's Edge?
The correct distance d in the Parallel Axis Theorem for a cube's edge is determined to be √2a, where a is the length of the cube's edge. The moment of inertia I_edge about an axis through one of the edges is calculated using the formula I_edge = I_0 + md^2, resulting in I_edge = 13/6ma^2. The initial moment of inertia I_0 for the cube about an axis through its center of mass is given by I_0 = 1/6ma^2. This calculation is crucial for understanding rotational dynamics in rigid body mechanics.
  • Understanding of the Parallel Axis Theorem
  • Knowledge of moment of inertia calculations
  • Familiarity with Pythagorean theorem applications
  • Basic principles of rigid body dynamics
  • Study the derivation of the Parallel Axis Theorem in detail
  • Explore moment of inertia for different geometric shapes
  • Learn about the applications of moment of inertia in engineering
  • Investigate the effects of axis displacement on rotational motion
Students and professionals in physics, mechanical engineering, and robotics who need to understand the principles of rotational dynamics and moment of inertia calculations.
~angel~
Could someone please help me with a particular question to this problem?
Consider a cube of mass m with edges of length a. The moment of inertia I_0 of the cube about an axis through its center of mass and perpendicular to one of its faces is given by I_0 = 1/6ma^2. Find I_edge, the moment of inertia about an axis p through one of the edges of the cube.
Express I_edge in terms of m and a. Use fractions rather than decimal numbers in your answer.
You know how the parallel axis theorem is I_edge = I_0 +md^2, what exactly is d in this particular problem. I tried a/2, and I tried using pythagoras' theorem to determine one of the diagonals, getting an answer of d= sqrt(2a^2)/2. Both answers where wrong when i substituted it into the equation.
A picture is available below.
Any help would be appreciated.
d is the displacement of the axis from the center of mass.
Now,
[tex]I_{edge} = I_0 + md^2 = \frac{1}{6}ma^2 + \frac{1}{2}ma^2 = \frac{2}{3}ma^2[/tex].
That should be the answer.
Hi there,
To find the moment of inertia about an axis through one of the edges of the cube, we can use the parallel axis theorem, which states that the moment of inertia about any axis parallel to the original axis is equal to the moment of inertia about the original axis plus the product of the mass and the square of the distance between the two axes.
In this problem, the original axis is through the center of mass and perpendicular to one of the faces, and the parallel axis is through one of the edges. So, we can use the equation I_edge = I_0 + md^2, where d is the distance between the two axes.
To find the value of d, we can use the Pythagorean theorem. If we draw a diagonal from one corner of the cube to the opposite corner, we can see that the distance between the two axes is equal to the length of this diagonal. So, d = √(a^2 + a^2) = √2a.
Substituting this value into the equation, we get:
I_edge = 1/6ma^2 + m(√2a)^2
= 1/6ma^2 + 2ma^2
= 1/6ma^2 + 12/6ma^2
= 13/6ma^2
So, the moment of inertia about an axis through one of the edges of the cube is 13/6ma^2. I hope this helps! Let me know if you have any further questions.
  • · Replies 28 ·
