Solving Positive Integer Problems: First & Last Terms in nth Bracket
The discussion focuses on solving a mathematical problem involving positive integers bracketed in a specific pattern. The number of integers in the rth bracket is defined as 2^r - 1. Participants outline the method to determine the first and last terms in the nth bracket and demonstrate that the sum of the terms in the first n brackets can be expressed as 2^n - 1[(2^n) - 1]. Key techniques include using the geometric sum formula and telescoping sums to derive the necessary results.
  • Understanding of geometric series and sums
  • Familiarity with telescoping sums
  • Knowledge of basic algebra and integer sequences
  • Ability to manipulate mathematical expressions and formulas
  • Study the geometric series formula and its applications
  • Learn about telescoping series and their properties
  • Explore integer sequences and their summation techniques
  • Investigate mathematical induction for proving formulas
Mathematicians, educators, students studying number theory, and anyone interested in advanced problem-solving techniques involving sequences and series.
al_201314
Hi everyone,
This is my first post here :smile: Anyway I have problems solving this question wonder anyone could help give me some clues as to how to go about it. Here goes:
The positive integers are bracketed as follows,
(1), (2,3), (4,5,6,7), (8,9,10,11,12,13,14,15), ...
No. of integers in the rth bracket is 2^r-1. State stae first term and last term in the nth bracket. Hence, show that the sum of the terms in the first n brackets is 2^n-1[(2^n)]-1].
Thanks very much.. I have absolutely no clue..
alvin
Start by finding how many numbers are in the first n brackets, which is just the sum of the first n powers of 2 (use the geometric sum formula). This will let you know the first and last number in each bracket. Then, to find the sum, use the sum of the first n positive integers, and plug in what you just found for n. If you don't know the sum of the first n integers, the easiest way to find it is to use a telescoping sum:
[tex]\sum_{k=1}^{n} (k+1)^2 - k^2[/tex]
If you were to write this out term by term, you'd see each term cancels except the first and last. Now that you have this sum, rewrite it as:
[tex]\sum_{k=1}^{n} k^2+ 2k + 1 - k^2 = \sum_{k=1}^{n} 2k + 1[/tex]
from which the result should follow pretty easily.
I got it.. thanks status.
  • · Replies 17 ·
