How Do I Calculate the Magnetic Force on a Coil from a Circular Ring?
The discussion focuses on calculating the magnetic force on a coil positioned along the axis of a circular ring carrying a current. The derived formula for the force, F, is given as F = -\frac{\mu_0 II'nSa^2}{2} ((a^2 + (\frac{l}{2} - d)^2)^\frac{-3}{2} - (a^2 + (\frac{l}{2} + d)^2)^\frac{-3}{2}). The key approach involves using the integral F=\int I(dl\times B), where B represents the magnetic field generated by the ring. Participants emphasize the importance of understanding the integration process to arrive at the final expression for force.
  • Understanding of magnetic fields and forces, particularly Ampère's Law.
  • Familiarity with the Biot-Savart Law for calculating magnetic fields from current-carrying conductors.
  • Knowledge of calculus, specifically integration techniques.
  • Concept of magnetic permeability, denoted as μ₀.
  • Study the Biot-Savart Law to understand how to calculate magnetic fields from current distributions.
  • Learn about Ampère's Law and its applications in magnetic field calculations.
  • Practice integration techniques relevant to physics problems, focusing on vector calculus.
  • Explore the concept of magnetic permeability and its role in electromagnetic theory.
Students and professionals in physics, electrical engineering, and anyone involved in electromagnetic theory or applications of magnetic forces in coils and circuits.
meteorologist1
I'm stuck on the following problem:
A long thin coil of length l, cross-sectional area S, and n turns per unit length carries a current I. It is placed along the axis of a large circular ring of radius a, which is carrying a current I'. If d is the displacement of the center of the coil from the center of the ring along the coil axis, find the force on the coil as a function of d.
I'm not sure what formulas to use, and what I have to integrate to get the following result:
[tex]F = -\frac{\mu_0 II'nSa^2}{2} ((a^2 + (\frac{l}{2} - d)^2)^\frac{-3}{2} - (a^2 + (\frac{l}{2} + d)^2)^\frac{-3}{2})[/tex]
Thanks.
Hello,first post ever, you could try to use the force from the formula
[itex]F=\int I(dl\times B)[/itex]
Where B is the field from the ring
