Understanding Physics Terms: A Matching Activity
  • Thread starter Thread starter joejo
    Physics Terms
The discussion revolves around a matching activity involving physics terms and their definitions, specifically focusing on concepts such as work, energy, and forces. Participants are attempting to verify their matches for terms like joule, potential energy, and kinetic energy against provided descriptions.
  • Participants are sharing their interpretations of the definitions and questioning the appropriateness of certain matches, particularly for joule and potential energy. Some express confusion about the clarity of the definitions provided by the teacher.
There is ongoing dialogue with participants offering alternative views on the definitions and suggesting swaps between terms. Some participants acknowledge the difficulty in matching terms accurately, while others express uncertainty about the correctness of their choices.
Participants mention that the definitions provided by the teacher were unclear, which has contributed to the confusion in matching the terms correctly. There is also a recognition that some definitions do not align well with the terms they are meant to describe.
joejo
hi its me again...
I just want to verify my work is correct so that my teacher won't claim its wrong...its a really simple matching activity...thanks in advance
Match following words with most appropriate description. Place the words for the term on the line beside the description.
Work, positive work, negative work, work-energy theorem, work-kinetic energy theorem, mechanical energy, kinetic energy, potential energy, gravitational potential energy, joule, conservative force, non-conservative force.
1. joule energy that is stored in by an object.
2. gravitational potential energy achieved by doing work against the force of gravity.
3. potential energy the transfer of mechanical energy.
4. kinetic energy the energy of motion.
5. mechanical energy combination of kinetic and potential energy.
6. work-kinetic energy theorem the special relationship between doing work on an object and
the resulting kinetic energy of the object.
7. negative work removes energy from an object.
8. positive work adds energy to an object.
9. conservative force when a force does work on an object and the amount of work
done is independent of the path taken.
10. non-conservative force when a force does work on an object and the amount of work
done is path-dependent.
Here's my two cents worth.
#1: A joule is a unit of energy. It does not necessarily need to be stored by the object. It can be an amount of energy required to do something, or an amount of energy created, etc...
#3: Your definition of Potential Energy needs work. Potential energy is a form of energy due solely to position or arrangement. It is not a transfer of energy.
#7: You may want to add that the net force doing the work is in the opposite direction as the displacement.
#8: You may want to add that the net force doing the work is in the same direction as the displacement.
im lost...i found those were the best ones that fit according to the choice of words we had above...my teachers defintions weren't clear so its hard to match...can someone tell where i went wrong and if so wat is the correct answer
I'm lost, too, by which definition would best fit joule, which, as FredGarvin said, is a unit of measure.
Best among the definitions available for potential energy would be "energy that is stored in by an object".
That only leaves one choice for joule.
so what i have so far...does it look right?
joejo said:
hi its me again...
1. Joule - unit of energy equal to applying a force of 1N across 1m.
2. GPE - potential energy attained from being in a gravitational field
3. PE - energy attained by being in a certain position or state
5. ME - total amt of energy an object has.
Whoops. Sorry. I didn't read the entire original post. I suppose that would help, wouldn't it? My bad.
I would swap 1 and 3. I wouldn't be very happy about it, but I'd do it nevertheless.
you guys are totally losing me! can someone please tell me what's wrong and what's right! thanks
everything is right BUT just switch 1 and 3
ohh okay thanks!
how can joules be...the transfer of mechanical energy.
It isnt, joules is a unit of energy, but none of your definitions match this.
i know they dont...thats not the question tho...which one best matches them...there are more words above...check it out please
how can potential energy be...the transfer of mechanical energy ?
well it cant...but it can't be joule either there's a few more terms above...do they match...
Most the other terms fit their descriptor. Those two definitions arent accurate for either joule or potential energy.
i think you had best go with your original list - 1 and 3 are both unsatisfactory, but swapping them makes them more so.
adi
oh okay thanks
  • · Replies 58 ·
