Find the lowest frequency where the receiver is a node
  • Thread starter Thread starter Physicsisfun2005
    Frequency Receiver
The discussion focuses on calculating the lowest frequency at which a receiver becomes a node in a two-speaker setup, with speakers positioned 2.5 meters apart and the receiver located 3 meters from one speaker and 3.5 meters from the other. The key relationship used is the path difference, Δd, which must equal half a wavelength for a node to occur, expressed as Δd = n(λ/2). By determining the maximum wavelength using the formula λ = (2Δd)/n and applying the wave equation v = λf, the frequency can be derived. Additionally, the number of nodal lines is contingent on the wavelength.
  • Understanding of wave interference principles
  • Familiarity with the wave equation v = λf
  • Knowledge of path difference in wave phenomena
  • Basic concepts of nodal and antinodal lines in wave patterns
  • Study the principles of sound wave interference and node formation
  • Learn about the double slit diffraction and its mathematical foundations
  • Explore the relationship between wavelength and frequency in various mediums
  • Investigate the calculation of nodal lines in different wave setups
Students and educators in physics, particularly those focusing on wave mechanics, sound wave interference, and practical applications of wave theory in classroom settings.
Physicsisfun2005
our teacher gave us this one in class and its not one of the "regular" ones we do so i same not sure how to set it up w/o getting messy numbers.
2 loud speakers 2.5m apart and a reciever 3m from one speaker and 3.5m from the other.
a. find the lowest frequency where the receiver is a node
b. # of nodal lines
to get the wavelength in order to find the frequency for (a.) do i just use the relationship X/L=n(lambda)/d?
b. # of nodal lines
This is analagous to double slit diffraction for light. The sound waves from the two speakers interfere and create a pattern of loud, soft areas along a 'screen line'.
But I think the question can be answered more easily than by using a diffraction pattern formula. A node occurs where the difference in the distance of the receiver from speaker1 to speaker2 has to be 1/2 a wavelength. So:
[tex]\Delta d = n\frac{\lambda}{2}[/tex]
[tex]\lambda = \frac{2\Delta d}{n}[/tex]
So what is the maximum wavelength? From that and the wave equation [itex]v = \lambda f[/itex] you can work out the frequency.
The number of nodal lines depends on wavelength. Can you work out the angle between nodes by working out the distance the next node would be from the receiver?
AM
Imagine the two speakers as two ends of a rope in which the wave is travelling.Now you know that for this kind of a rope , the relation is given by:
L=n(wavelength)/2
Also distance between two nodes or antinodes is always equal to (wavelength/2)
according to your question L=2.5m
You can calculate wavelength as per given distance of nodes, which will give you the value of n which will be the lowest.
  • · Replies 27 ·
11K
