Finding Local Extrema with Derivatives
The discussion focuses on finding two positive numbers whose product is 108, while minimizing the sum of the first number plus three times the second number. The user derives the function S = (108/y) + 3y and seeks assistance with calculating its derivative. The correct first derivative is dS/dy = -(108/y^2) + 3, leading to the critical point y = 6. The second derivative, 216/y^3, confirms the nature of the critical point, indicating a local minimum when positive.
  • Understanding of derivatives and their applications in optimization
  • Familiarity with the power rule for differentiation
  • Knowledge of critical points and their significance in calculus
  • Ability to interpret second derivatives for determining local extrema
  • Study the power rule in calculus for differentiating polynomial functions
  • Learn about critical points and how to identify them in optimization problems
  • Explore the concept of second derivatives and their role in determining concavity
  • Practice graphing functions alongside their first and second derivatives for better understanding
Students studying calculus, particularly those focusing on optimization problems, as well as educators seeking to clarify derivative concepts and their applications.
scorpa
Hey there!
You guys aren't going to believe that I can get stuck on something this pathetically easy, but I have to ask anyway.
Find two positive numbers whose product is 108 and the sum of the first number plus three times the second number is a minimum.
Here is what I've done:
xy = 108
x + 3y = S
Let x and y be the two numbers, and S the sum.
To find S substitute x = (108/y) into x + 3y = S
S = (108/y) + 3y
Now I need to take the derivative of the function, and set it equal to zero to find a critical number, but I can't get the right answer for this part, which is stupid because it should be so darn easy. I haven't done derivatives in awhile and now I am starting to forget them :mad:
This is what the book says :
dS/dy = -(108/y^2) + 3 = 0
3 = 108/y^2
y^2 = 36
y = 6
The second derivative the book says is 216/y^3
Can someone please explain how they got the derivatives to me? I feel absolutely stupid having to ask this but I figured I had better ask now so I understand it later. Thanks so much :redface:
What are the derivatives of a constant,of [itex]y=x[/itex] and [itex]y=\frac{1}{x}[/itex]...
U need them all.
Daniel.
scorpa said:
S = (108/y) + 3y
I'd rewrite this as [tex]S = 108y^{-1} + 3y[/tex]
You use the power rule to find the derivative of each term. This identifies your critical points, but doesn't tell you for sure whether you have a local minimum or a local maximum.
Use the power rule, again, to find the derivative of your derivative (the second derivative). If the second derivative is greater than 0, you have a local minimum; If less than 0, a local maximum.
If you don't understand why, then graph your original function, your first derivative, and your second derivative. The relationship between them should be a little clearer.
10K
  • · Replies 18 ·
