Making a gold solution for plating.
  • Thread starter Thread starter MaximumTaco
    Gold
The discussion revolves around methods for creating a gold solution suitable for electroplating without using nitric acid, cyanides, or other difficult-to-obtain chemicals. Participants explore alternative chemical combinations and processes, focusing on the feasibility and effectiveness of various approaches.
  • One participant inquires about dissolving metallic gold using common chemicals like concentrated HCl, H2SO4, and urea, questioning the potential of urea to form a complex with gold.
  • Another participant argues that the standard electrode potentials of the suggested chemicals are insufficient to dissolve gold, suggesting a mixture of HCl, KNO3, and urea as a possible method, while cautioning about the expected outcomes.
  • A third participant mentions that a 1:3 mixture of HCl and HNO3, referred to as "Royal Water," can dissolve gold, producing trichloride of Aurum.
  • Another participant seeks clarification on how to proceed after dissolving gold chloride, proposing the use of potassium permanganate in a strong base like sodium hydroxide as an alternative method to dissolve gold.
  • A later reply expresses interest in the potassium permanganate and sodium hydroxide method but notes the lack of nitric acid as a limitation.
Participants present multiple competing views on the methods to dissolve gold, with no consensus reached on a definitive approach. Some methods are proposed as alternatives, but uncertainty remains regarding their effectiveness.
Participants express limitations based on the availability of specific chemicals and the effectiveness of various proposed methods, indicating that the success of these methods may depend on specific conditions and concentrations.
Individuals interested in electroplating, chemistry enthusiasts exploring alternative chemical processes, and those seeking practical methods for dissolving gold without hazardous materials may find this discussion relevant.
MaximumTaco
Hi,
I'm trying to figure out how to dissolve metallic Au in solution, for an electroplating solution, without the use of Nitric Acid, Cyanides, or other chemicals which i cannot obtain.
I can obtain many more common (less suspicious and dangerous) chemicals, such as concentrated HCl, H2SO4 and H2O2, NaOH, Urea, and many other things.
I thought about distilling conc. H2SO4 out of KNO3 but i don't have a proper distillation apparatus that will handle this.
I read somewhere that a Urea solution will complex with gold, forming a solution - is this right? does anyone know the details needed to make this work?
Could trichloroisocyanauric acid, or Na dichloroisocyanaurate, having a structure derived from cyanide, be used to form a suitable solution?
Chemistry news on Phys.org
alone, none of those will do anything. The standard electrode potential of gold is 1.5V.
H2SO4 is only 0.17V, HCl is not an oxidizer, NaOH is a reducer, and urea complexes are only formed when ions mix (the gold would need to be already dissolved). Even HNO3 is too weak at 0.8V
Try mixing HCl, KNO3, and a little bit of urea together. Don't panic if it foams since urea is a base. Throw in a little tiny piece of gold and see if it dissolves.
The idea is that the voltage is more spontaneous when the gold concentration is low and the acid/nitrate concentration is high. What the urea complex does is in a sense "remove" gold ions from the mixture so the reaction is still spontaneous.
Don't get your hopes up though. I wouldn't expect it to work with anything less than concentrated HCl with concentrated nitric acid.
The mixture of [itex]\mbox{HCl}[/itex] and [itex]\mbox{HNO}_{3}[/itex] in a ratio of 1:3 will dissolve gold giving trichloride of Aurum.
Daniel.
dextercioby said:
The mixture of [itex]\mbox{HCl}[/itex] and [itex]\mbox{HNO}_{3}[/itex] in a ratio of 1:3...
"Royal Water"...;)
Where would he got from here? How do you dissolve gold chloride?
I thought of another way you could go about doing this. You can dissolve the gold with potassium permanganate (Condy's Crystals at the pet store) in strong base like sodium hydroxide (Drano or degreaser).
-permanganate dissolves the gold
-hydroxide precipitates the gold
Filter the precipitate from the solution, then add nitric acid to dissolve the gold hydroxide.
Hmm, that sounds good. I have plenty of KMnO4 and NaOH
But no Nitric Acid.
18K
10K
10K
