Roxy
- 52
Whats the heat capacity of NaOH I can't find it anywhere?
The discussion revolves around the heat capacity of sodium hydroxide (NaOH), specifically whether it pertains to solid NaOH or its solutions. Participants seek to clarify the appropriate values and context for calculations involving heat generation.
There is no clear consensus on the heat capacity of NaOH, as participants discuss both solid and solution forms, leading to differing implications for calculations. The discussion includes both helpful and unhelpful responses, indicating mixed views on the adequacy of the replies.
Participants express uncertainty regarding the specific form of NaOH being discussed (solid vs. solution), which affects the heat capacity values. The conversation also highlights the need for clarity in responses to avoid confusion.
You are working with solid NaOH (not solution) ?!Roxy said:Whats the heat capacity of NaOH I can't find it anywhere?
Gokul43201 said:You are working with solid NaOH (not solution) ?!
Why do you need the heat capacity ?
How is the heat to be generated?Roxy said:I need to calculate heat generated so I'm using this formula:
q=mc(delta)t
and i need c
You didn't answer my (implied) question.Roxy said:I need to calculate heat generated so I'm using this formula:
q=mc(delta)t
and i need c
