Driving 7-Segment Display from 200Hz Clock Signal
  • Thread starter Thread starter david90
    Clock Signal
The discussion focuses on driving a 7-segment display using a 200Hz clock signal derived from a 500MHz source. The input clock signal must be declared as an input in the display module, and it should be utilized within an always block (i.e., always(@posedge clk)) to ensure proper synthesis as a clock signal. A flip-flop can be employed as a 2-output counter to cycle through the 4 multiplexed segments, although there is a minor risk of race hazards at these frequencies.
  • Understanding of digital clock signals and their applications
  • Familiarity with Verilog or VHDL for hardware description
  • Knowledge of flip-flops and their operation in digital circuits
  • Experience with multiplexing techniques for display systems
  • Research Verilog always block syntax for clock signal implementation
  • Learn about flip-flop configurations and their role in counting
  • Explore multiplexing methods for driving multiple 7-segment displays
  • Investigate race conditions in digital circuits and mitigation strategies
Electronics engineers, hardware designers, and students working on digital display systems or clock-driven applications.
david90
I have a clock module that divides a 500mhz signal to a 200hz signal, and another module that is suppose to use the 200hz clk signal to drive 4 multiplexed 7segment display. My question is how do I input the clock module signal into the 7segment display module?
What is the "another module" doing? Is it using the 200hz to cycle the 4 seg's?
If so i'd use a flip flop as a 2 output counter (using Q and clk). Slight risk of race hazards but affordable at these frequencies.
david90,
The clock enters the module like any other signal. It should be declared as an input. If you use the signal as the argument in an always block (i.e. always(@posedge clk)), the synthesizer will know it's a clock. You do not have to do anything special to declare that an input signal is a clock; it's a clock if you use it as a clock.
- Warren
  • · Replies 21 ·
  • · Replies 46 ·
  • · Replies 28 ·
