What is the Relationship Between Force, Power, and Work in a Particle System?
The discussion revolves around the relationship between force, power, and work in a particle system, specifically focusing on the integration of force over time and its implications for calculating work and power. The original poster presents a scenario involving a force function F(t) acting on a particle, with initial conditions provided.
  • Participants explore the integration of force and its relationship to work and power, questioning how to account for the fact that both force and position are functions of time. There are discussions about the definitions of work and power, particularly in the context of variable forces.
Participants are actively engaging with the problem, offering various approaches to express work and power in terms of force and velocity. Some guidance has been provided regarding the use of integrals and the distinction between instantaneous and average power, but no consensus has been reached on the best method to proceed.
There is an emphasis on the need to adapt calculations based on the functions of time involved, and participants note the importance of considering the scalar nature of work in relation to vector quantities. The discussion reflects a mix of interpretations regarding the application of formulas in the context of non-constant forces.
sAXIn
I have a question where I have a force F(t) acting on particle ,
I intgrate 2 times and find X(t) , i used innitial conditions given x=0 , t=0 , v=0 .
1) now they ask me to write the work done by the power between t=0 , t=<epsilon> I know that dw=F dot DX but here the f and x are both functions of t so ... ?
2) after that i need to write the power of the force on time t>0 i think interval t=0 , t=t ... ?
thank's in advance
You have dx/dt = ... -> dx = ...dt
[tex]W = \int_{x_0}^{x}Fdx = \int_{t_0}^{t}F(t)...dt[/tex]
You know F in terms of t to get the solution.
2)
P = Fv = F(t)v(t), which you already have.
yes but you don't put in consideration that x is function of t it\s integral of F(t)d(x(t)) or something
2) I know that p=FV when the force is constant here it isn't ?!
sAXIn,
There are two options actually.
Suppose (i take x and F both along the x-axis, but you know that the integrandum of the work is a SCALAR product of two vectors)
F = 2
x = t²
You just need to substitute everything towards t...
Then [tex]W = \int Fdx = \int 2d(t^2) = \int 4tdt[/tex]
Make sure that you adapt the boundaries.
or, since you know the velocity , you can calculate the kinetic energy and you know that work is equal to the difference in kinetic energy between the end and beginning of the motion : [tex]W = E_{k}^{FINAL} - E_k^{BEGINNING}[/tex]
marlon
1) Of course it is used:
[tex]W = \int_{t_0}^{t}F(t)v(t)dt[/tex]
where dx = v(t)dt. So what's the problem.
2)
You need instantaneous power, which is the product of instantaneous force at time t and instantaneous velocity at time t. If you had used
[tex]P = \frac{\Delta W}{\Delta t}[/tex]
then it would have been average power that doesn't apply in this problem.
If you're skeptic:
[tex]P = \frac{d}{dt}[W(t)] = \frac{d}{dt}(\int_{}^{}F(t)vdt) = Fv[/tex]
where you well know that dx = vdt.
I got it's the same : I can integrate f(t)v(t)and then def. by dt so its = power or just skip it and f(t)v(t) is my power ! thanks a lot ...
  • · Replies 25 ·
  • · Replies 21 ·
  • · Replies 16 ·
