HELP - Molar mass changes at stp?
  • Thread starter Thread starter rocketboy
    Mass
The discussion revolves around calculating the molar mass of butane using experimental data, specifically under varying conditions of temperature and pressure. The original poster is encountering discrepancies in their calculations and is seeking clarification on the expected consistency of molar mass across different conditions.
  • The original poster attempts to calculate the molar mass of butane based on experimental data, questioning the validity of their results and the methodology used. Some participants raise concerns about the consistency of molar mass under different conditions, while others suggest that the calculations may be flawed due to incorrect assumptions or equations.
Participants are actively engaging with the original poster's calculations, with some providing insights into the nature of molar mass and its expected constancy. There is recognition of potential errors in the original poster's approach, but no consensus has been reached regarding the specific issues at play.
The original poster has acknowledged a correction in the mass of butane used, which has significantly affected their results. There is an ongoing discussion about the implications of temperature and pressure changes on molar mass calculations, with participants questioning the assumptions made in the calculations.
rocketboy
PLZ HELP - Molar mass changes at stp??
Hey, I have this lab report due tomorrow, and I seem to be getting some discrepencies in my calculations. I am calculating the molar mass of butane, without using the values from the periodic table, using data obtained by the experiment below:
Pressure: 101.09 kPa
Temperature: 23ºC --> 296 K
Initial Mass of Lighter: 18.19g
Secondary Mass of Lighter: 18.06g
Mass of Butane used: 0.15g
Volume of Butane: 50.2
I won't bother you with error propagation as it is easy to caculate, so disregard that. Below are my calculations for the molar mass of butane, at the temp and pressure given above and at STP (standard temp and pressure).
Am I doing this properly? Do my results make sense? (Ignore the "..." they are for placement)
Molar Mass of Butane at Given Temperature and Pressure:
50.2 +/- 1.0mL X 1.0L = 5.02 x 10^-2 L
......1000mL
P = nRT --> n = PV
...V.....RT
n = 101.09kPa (5.02 x 10-2L)
...8.31kPa.L/mol.K (296K)
n = 2.06 x 10^-3 molButane
M = m
...n
M = 0.15g .
...2.06 x 10^-3 molButane
M = 72.71g/molButane
Molar Mass of Butane at STP:
T1 = 296K P1 = PTotal – PH20 P2 = 101.3kPa
T2 = 273K = 101.09kPa – 2.81kPa V1 = 50.2mL
= 98.28kPa
50.2 mL X 273K X 101.3kPa = 47.7mL = 4.77 x 10^-2 L
...296K...98.28kPa
P = nRT --> n = PV
...V...RT
n = 101.3kPa(4.77 x 10^-2 L)
...8.31kPa.L/mol.K (273K)
n = 2.13 x 10^-3 molButane
M = m
...n
M = 0.15g .
...2.13 x 10^-3 molButane
M = 70.42g/molButane
I know I've done something wrong but don't know what.
Thanks you SO much,
-Jon
OMG! Sorry, i made the dumbest error. The mass of butane is 0.13g not 0.15...i subtracted the data wrong by 0.02 and it changed the answer by around 9g/mol!
but still, should i be getting different answers for each case? Why is this or is it not?
-jon
No, you should not be getting different answers. One mol of a quantity contains a specific number of molecules (Avogadro's number) and so has a specific mass. That doesn't change just because you change temperature and pressure (although the volume might.)
rocketboy said:
(snip)I won't bother you with error propagation as it is easy to caculate, (snip)
M = 72.71g/molButane (snip)
Thanks you SO much,
-Jon
You might try the "easy" part.
Oh I did the "easy" part in my lab notebook of course. Since i made the correction (post 2 of mine) i have values approx 61 and 64. But I think I'm using the wrong equation or something..because ivy is right, molar mass should always stay the same.
14K
11K
15K
