Calculating Force of Friction on a Sliding Block on a Ramp
The discussion centers on calculating the force of friction acting on a block of weight W Newtons sliding down a ramp inclined at angle A degrees. The critical angle is identified as the point where the component of gravitational force parallel to the ramp equals the force of friction. Once the block begins to slide, the frictional force decreases, and to maintain constant velocity, the angle must be adjusted. The relationship between the normal force, coefficient of friction, and force of friction is established as F sub N (normal force) * Coefficient of Friction = F sub F (force of friction).
  • Understanding of Newton's laws of motion
  • Knowledge of basic trigonometry for calculating force components
  • Familiarity with the concepts of normal force and friction
  • Ability to manipulate equations involving forces
  • Study the derivation of the equations for frictional force in inclined planes
  • Learn about the coefficient of friction and its dependence on surface materials
  • Explore the effects of different angles on the motion of sliding objects
  • Investigate the role of acceleration in dynamic friction scenarios
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of sliding objects on inclined surfaces.
poikonen03
There is a block of W Newtons and a ramp is A degrees above the horizontal. At this angle the block begins to slide. How do I find the force of friction and then it should be quite easy to find coefficient of friction. (I already have already solve for the normal force Fw and the force parallel the ramp Fp)?
If you solved for the normal force, you were very close to finding the component of gravitational force parallel to the plane. Friction overcomes (equals in magnitude) that force for small angles. When the block begins to slide, friction has just been overcome. At that critical angle, the component of gravity parallel to the plane equals the force of friction.
Once sliding starts, the frictional force gets smaller and there is some acceleration. To find the frictional force when the block is sliding, reduce the angle to achieve constant velocity after you give the block a little push to get it started.
so basically F sub P (force parallel to ramp) = F sub F (force of friction) since there is no accel...so F sub N (normal force) * Coefficient of Friction = F sub F
thanks :smile:
  • · Replies 20 ·
  • · Replies 32 ·
