What is the Relationship Between Voltage and Current in Terms of Units?
The discussion revolves around the relationship between voltage, current, and their respective units of measurement. Participants explore the definitions and conversions of these electrical quantities, particularly in the context of different unit systems such as cgs and mks. The conversation includes technical reasoning and clarifications regarding the nature of amperes and their measurement.
  • One participant suggests that current can be expressed as gm/s and voltage as cm^2/s^2, questioning the validity of these units.
  • Another participant provides a detailed derivation of the relationship between watts, volts, and amperes, emphasizing the conversion between cgs and mks units.
  • A participant raises a question about how amperage, defined by the flow of electrons, can be measured in cm/s, expressing confusion about the relationship between charge and length.
  • Another participant asserts that amperes cannot be expressed in cm/s, clarifying that the ampere is a fundamental unit in the SI system and discussing its definition related to force between current-carrying wires.
  • One participant explains that voltage is defined as joules per coulomb, linking it to potential energy and power calculations.
  • A later reply corrects a misunderstanding regarding the units of amperage, clarifying that it is measured in coulombs per second (C/s) rather than cm/s.
Participants express differing views on the appropriate units for measuring current, with some confusion regarding the relationship between amperes and length. While there is a consensus on the definitions of voltage and power, the discussion remains unresolved regarding the initial claims about current's unit representation.
Some participants rely on specific definitions and conversions that may depend on the chosen unit system, and there are unresolved questions about the implications of these definitions on the understanding of electrical quantities.
KC9FVV
Hello!
I was reading Asimov on Physics the other day, and found that a watt is a measure of gm cm^2/s^3. That got me thinking, if voltage times current equals watts, what would voltage and current be a measure of? I have been trying to figure it out for a while, and came up with: current= gm/s and voltage= cm^2/s^2. That is the only way I could make current work, but voltage just doesn't seem right to me.
Cody,
Watts can be expressed in various systems e.g. cgs (cm gm sec), mks (m kg sec). To convert Watts to cgs you may want look at a table of conversions in physics or engineering texts
or a verifiable online ref... for example ---> http://users.aol.com/tspquinn/units.html
1W = (1 J/s)
1 J = 10^7 ergs
1 erg = 1 dyne cm
1 dyne = 1 gm cm/s^2
So now calculate watts in cgs.
1W = (1 J/s)*(10^7erg/J)*(1dyne cm/erg)*[(1 gm cm/s^2)/dyne]
cancel J, erg,dyne... leaving you 1W (cgs) = 10^7 gm cm^2/s^3
Which makes sense because converting this to mks
(10^7 gm cm^2/s^3)(1m/100cm)(1m/100cm)(1kg/1000gm) =
(10^7 gm cm^2/s^3)[1m^2 kg/(10^4 cm^2 10^3 gm)] =
cancel gm, cm^2 ...
10^7 kg m^2/ ((10^4*10^3) s^3) so 1W (mks) = 1 kg m^2 /s^3
So cgs and mks systems differ by constant factor 10^7,
if i choose to stay in mks (table including voltage an current)
e.g. ref ---> http://www.csee.umbc.edu/help/theory/units.shtml
I can go through a similar derivation for voltage and current but you get the idea, to save time I obtain the following:
1V = 1 (kg m^2)/( s^2 c)
1A = 1 c/s
1W(mks) = (kg m^2 c)/ (s^2 s c) , cancel c (c - Coulombs)
= 1 kg m^2/ s^3
Thanks, but I still have one question. How can amperage - measured by the number of electrons that go by a certain point in a certain amount of time - be measured using cm/s? With mass I could see... 1.24 quintillion electrons weigh a certain amount, but how do 1.24 quintillion electrons have a length?
I didn't read the preceding post, but there is no way that amperes can be expressed in cm/s -- those are units of velocity! In fact, the ampere is fundamental unit in the SI system, just like the metre, kilogram, and second.
http://physics.nist.gov/cuu/Units/units.html
It is not a derived unit, so it cannot be expressed in terms of these other three. Current was a physical quantity that demanded a new unit of measure. I won't try to state the official def'n of the ampere, because I'll get it wrong. You're better off looking it up. I think it has something to do with "the current required to produce _______ amount of force between two infinitely long, parallel, current - carrying wires." The ampere has, in turn, been used to define the coulomb (the amount of charge passing a point in one second when there is 1 A of current). I'm not sure whether current has a different unit in the cgs system, which you seem to be using, but I don't think so. I remember reading also that there is no British system of electrical units. Thankfully.
One volt is one joule per coulomb (J/C), which makes sense because voltage is actually potential difference. E.g. the potential difference between two terminals can be interpreted as the potential energy per unit charge gained or lost as charge flows between the terminals. So it makes sense that the voltage drop across a resistor for example, times the current flowing through that resistor, gives you the power dissipated. For you have joules lost per coulomb times coulombs going by per second = joules lost per second.
Mathematically: J/C * C/s = J/s = W
But you wanted to see everything in base units:
[tex]J = \frac{kg\cdot m^2}{s^2}[/tex]
[tex]V = \frac{J}{C} = \frac{J}{A\cdot s} = \frac{kg\cdot m^2}{A\cdot s^3}[/tex]
[tex]W = V\cdot A = \frac{kg\cdot m^2}{s^3}[/tex]
You misread. The units given were c/s not CM. An amp is a coulomb/second or C/s.
  • · Replies 38 ·
  • · Replies 16 ·
  • · Replies 17 ·
